Tattoo Machine Out of Household Material
163,576
56
50
Introduction: Tattoo Machine Out of Household Material
build a prison style tattoo machine out of househeld items.
tools: needle nose pliers, knife, philips head screwdriver
parts: toothbrush, ball point pen, guitar string, mechanical pencil eraser, and electric motor from tape recorder
Step 1: Find a Motor
i found mine in a tape recording machine. I heard that tape machine motors were the standard, but i have also heard of tattoo machines made of nintendo 64 rumble pack motors. When you find your motor, rip it out and take note of the positive and negative wires. Also rip off the stock gear attached to the motor crank. You will be replacing the stock gear with a mechanical pencil eraser fitted to the guitar string needle.
Step 2: Make the Frame
I used a plastic tooth brush. First I cut off the head with the bristles. Then i melted a 90 degree angle in the top of the brush for the motor to rest on.
Step 3: Cut Up a Pen for the Tube
find a normal ball point pen and take out the ink and the tip to use the shell for the tube of your needle. Get those guts out and then tape the tube to the outside of the toothbrush. Then connect the toothbrush frame to the motor so that the eraser gear hangs over the edge of the toothbrush. Take your guitar string and bend it in a 90degree angle. Then stick the angled string through the eraser stuck to the motor near an edge. Next cut the needle so that it only pokes through the tube when the motor is turned on.
Step 4: Get Stoked, You're Done
I have my motor connected to a power source with alligator clips, but it would work better with a power foot switch . Connect it, dip it in ink and you're ready to go ruin lives.
Be the First to Share
    • Back to School: Student Design Challenge
    • Microcontroller Contest
    • Fandom Contest
      Fandom Contest
    50 Comments
    Casper87420
    Casper87420
    Question 3 years ago on Introduction
    Can you use a CD disclaim motor instead of a tape deck Salman motor???
    ZainuM
    ZainuM
    4 years ago
    Tattooing it self is about being creative.being able to tattoo is what matters not what you use.i can tattoo with pins alone without machine so I see no problem with it.it works perfect from experience
    Froggie2942
    Froggie2942
    5 years ago
    I have a gun but dont know how to use it. I got a motor from old tape recorder and now I'm not sure how to hook it all up? Help plz
    MyiraS
    MyiraS
    6 years ago
    Didnt work ?
    Karma wangmo
    Karma wangmo
    6 years ago
    I tried a lot to make but it didnt work why can somebody can help me please.
    bobankarstens
    bobankarstens
    6 years ago
    @veverica Umesto gumice koja ide na osovinu motora,uzmi jedno dugme i stavi osovinu u jednu rupu na dugmetu.Iglu stavi u rupu na suprotnoj strani dugmeta i voila!!!
    bobankarstens
    bobankarstens
    6 years ago
    @MUNCHINE > It's not f..king Spanish nor Bosnian,it's SERBIAN,capisch?!?
    sresrose1206
    sresrose1206
    12 years ago on Introduction
    This cannot POSSIBLY be safe. Tattoo parlors (you know, where you go and pay a PROFESSIONAL who's taken classes and earned certificates and knows how to handle the bodily fluids and proper disposal of equipment and such-like) can get shut down for not having sanitary working conditions - what makes you think your house is clean enough? I'm willing to bet that if you're making a tattoo gun with sewing machine needles and parts from a tpe player, you're not paying any attention to sterilizing your equipment, buying actual tattoo ink, and cleaning your skin before tattooing it. Are you trying to contract staph infection from those nasty bugs that live on your skin?
    i own airsoft
    i own airsoft
    professionals dont take classes the most they would do i have had an apprenticeship or maybe taken art classes but there is no such thing as a tattoo certification for everywhere the most is to get certified to tattoo at one shop
    BerinaSpliffta
    BerinaSpliffta
    10 years ago on Step 4
    he asked you how did u make a needle to go up n down n not in circle? ;) itz not spanish,itz bosnian language lol :D
    the circular action of the motor is converted to an eliptical one by the use of a cam.  this is why the needle is able to travel up and down.
    dsman195276
    dsman195276
    14 years ago on Introduction
    this is a very bad idea. good job on making it but i would never use this. you could get STAFE infection.
    lane29
    lane29
    Reply 12 years ago on Introduction
    i allways clean mine withh iodine
    Eidolonmyst
    Eidolonmyst
    Reply 14 years ago on Introduction
    It's Staph Infection, and if you use sterile tat needle bars you'll be fine.
    dsman195276
    dsman195276
    oops, i am not a expert on the subject. all i know is that it is called a STAPH (my typing used to be really bad, so i missed that typo) infection, and you can get it from tattoos with out sterile needles.
    eyerobot
    eyerobot
    Finally someone made sense out of the guitar string method for me, Good job chris.
    The string is seated off center, On an eraser, Attached to a horizontally mounted motor shaft, Then bent downward towards the tube.
    The off center movement of the guitar string forces it up and down.
    Just in case someone else cant wrap their brain around how this thing works.
    One question i dont see answered in any of these instructibles about tattoo machines is, How deep should the needle penetrate into the skin?
    A minimum distance would do for a start position, As I realize skin has different thicknesses, But one setting for all skin types seems possible, And a far sight safer than eyeballing it.
    I just dont like the idea of gouging someones muscles, Just to learn how far is too far.
    dmwl
    dmwl
    13 years ago on Introduction
    I'm trying to do this can someone tell me how I get the motor to go I took it out of an old radio and it wont run on battery's or any thing else (I even tried to plug it straight into the wall nearly killed myself) :)
