@tweet_tree: Twitter Controlled Christmas Tree
Intro: @tweet_tree: Twitter Controlled Christmas Tree
Live streaming video of @tweet_tree is on USTREAM (The broadcast has ended, thanks to everyone who gave us a light show with Twitter!). See this article with the original formatting at DangerousPrototypes.com
@tweet_tree is a stand-alone network appliance based on our open source, business card size web platform. The web platform is available as a kit for $35, including worldwide shipping. Seeed Studio can assemble yours for $5 more.
Using itTo choose the color of our tree, just send a color to @tweet_tree on Twitter.
@tweet_tree red, green, purple, green, p, g, r, b
@tweet_tree understands red, orange, yellow, green, blue, and purple. Send one color, or combination of colors to morph through. Separate multiple colors with a comma. Only the first letter of the color matters, r,o,y,g,b, & p, are acceptable color commands.
@tweet_tree red, *ff0000, green, *00ff00, blue, *0000ff
You can also blend custom colors using 24bit hexadecimal color codes. Here's a color picking tool to help you choose values. Send the value as *rrggbb, where rr=red, gg=green, and bb=blue. We used the * designator because the more common # is already used for Twitter hash tags.
STEP 1: Overview
If there's are more than one color in a tweet, or multiple tweets, the tree fades between them until it reaches the most recently sent tweet.
STEP 2: Hardware
The tweet_tree has three primary components.
Web platform
Our open source web platform does the heavy lifting. It has all the hardware we need to connect to Twitter, parse tweets, and convert them to colors. The color(s) are stored in memory and sent to the ShiftBrite LED over a simple 3-wire interface.
The web platform is available as a kit for $35, including worldwide shipping. For an extra $5 Seeed Studio will assemble it for you.
ShiftBrite LED
A ShiftBrite high-power LED blasts the colors sent in the tweets.
- IO2->LATCH
- IO3->CLOCK
- IO4->DATA
- GND->GND
It only takes three pins to control the ShiftBrite, we used IO2-4 on the web platform IO header. The EI pin should be permanently enabled by connecting it to ground. The module requires a 5volt+ power supply, we tapped the same supply we used for the web platform.
Fiber optic tree
Our tweet_tree is a small fiber optic Christmas tree, but you could use more ShiftBrites to light a full-size tree or yard display.
We removed the original guts from the base of the fiber optic tree and replaced them with the ShiftBrite. A major concern was that the LED wouldn't be bright enough to replace the original mini-halogen lamp, but the ShiftBrite works perfectly.
STEP 3: Firmware
Firmware
The latest firmware downloads are on the project Google Code page. The code is written in C, and compiled with the free Microchip C30 demonstration compiler.
The firmware uses an adapted version of the #twatch source code to connect to Twitter over the internet. It opens a TCP connection and sends a search query for '@tweet_tree', the response is a JSON formatted data file like this.
A JSON parsing state machine searches through the data for the 'text' and the 'id' tags. The text tag value is processed for color commands. The value of the first id tag is stored too. We'll use it to limit results to new tweets in the next search query. Hint: try JSONView to work with JSON in Firefox.
If a new color command is found, the LED fades into the new color. If multiple commands or tweets are found, the colors morph from oldest to newest, with a 5 second pause between each. The tree always ends on the most recently tweeted color.
Every minute, or after completing a stored sequence, whichever takes longest, the web platform queries Twitter for fresh tweets. It appends the saved id tag value to the search query so the feed only returns new tweets. Twitter limits the number of queries you can make in an hour, but 60 is well below the limit.
The ShiftBrite is controlled with bitbang routines from our RGB remote control pumpkin project.
Compiling
This firmware uses the free Microchip TCPIP stack. If you want to compile the firmware yourself, download the TCPIP stack and follow the instructions in main.c.
STEP 4: Get One
Taking it further
Twitter-controlled holiday possibilities are endless. The web platform can Twitter-enable a Halloween or Christmas yard display. Multiple Shiftbrite modules could be tied together to light a large Christmas tree, or substitute a TLC5940 16channel LED driver to control individual LEDs.
Other web platform demos
Get one
2 Comments
the-super-reaper 14 years ago
ian 14 years ago
