now if I wanted to make an adapter to plug usb devices into my microUSB smart phone, how would I go about doing that? Pretty sure I can take care of relevant software changes required.
Your device has an A socket like an USB host (computer) has. The other side is a B plug like a cable has. If you want to use it to connect two cables to make them longer, wouldn't you better use a B type connector, so that you can use two standard A-B cables?
There are good reasons not to make USB cables too long. As the impedance of the cable grows with length, the timing gets more critical and the communication might stop. In better cases the device is just not recognized by the host, in worse cases it seems to work and just stops or produces errors from time to time.
Btw. The ground pin of the A jack (top one) in your PCB is not connected as there is a missing junction in the schematic.
I was trying to make it shorter and i couldnt find the connector like the pendrive. plan to get them :) About the PCB, yup i used solder to connect them
X
Autodesk Instructables
Your privacy is important to us, so please take a moment to indicate if we may collect and use your data.
We want you to have a good experience with us. To do this, we collect data about your online behavior or attributes and use advanced data analysis so that we may deliver new versions of our sites with customized content.
11 Comments
AudreyF22 6 years ago
A Diagram and layout PCB please ,thank you
masum199 12 years ago
vov35 12 years ago
rimar2000 12 years ago
zhenning 12 years ago
verence 12 years ago
