Pocket Sized LED (Altoids) Flashlight
Intro: Pocket Sized LED (Altoids) Flashlight
This "Ible" will detail how to make an LED flashlight in an Altoids smalls container. I had thought about making this a cooler more complex thing, but because I made it so simple it is very durable (if made well)
STEP 1: Supplies
You will need.
1 Altoids "smalls" tin
1 White LED (I used 3MM)
1 soldering gun/iron
1 ultra finepoint sharpie
1 small toggle switch
1 hotglue gun
1 dremel tool
2 Cr2032 watch batteries
and, Electrical tape, spare wire, and some needle files would be helpful.
1 hotglue gun
1 dremel tool
STEP 2: Mark Tin
When putting stuff in Altoids tins I like to mark where the lid closes to so I can stay below that line. Close the tin and run the sharpie around it, right under the lid. (don't worry, when the project is done you can clean it all off with alchohol and a rag).
STEP 3: Make Holes
Decide where you want the holes for your LED and your switch, since my LED was round I just drilled a hole the right size. But, my switch was rectangular so I drilled several (2) holes inside the small rectangle and filed the hole to size, if you want you can sand around the holes lightly just to make sure there are no sharp pieces of metal, go ahead and do it now. I'll wait... Done? Good. Continue on young one.
STEP 4: Make Battery Pack
STEP 5: Put It All Together
Solder the Battery pack to the switch and the LED. Make sure you have room to stretch the whole thing to fit the holes you made. and put it in the tin.
STEP 6: Glue It In
Using your holtglue gun glue it all in place and glue it good!
if made right this will be extremly durable (Ive dropped min 5' onto hardwood floor and it worked fine)
16 Comments
owen27 10 years ago
Schmidty16 10 years ago
oldanvilyoungsmith 10 years ago
BigMac96 14 years ago
oldanvilyoungsmith 14 years ago
ZanderArch 14 years ago
Berserk87 14 years ago
mason0190 14 years ago
hominid 14 years ago
