Webbed Fingers
Intro: Webbed Fingers
it a fairly simple way to give yourself webbed hands for those days your just feel fishy
things you will need
liquid latex ( i use brand X)
card stock
Q-tip
trace hand on card stock , if it helps make little tabs to help hold the card in place. cut them out and place in between your finger. the latex really just cover it on there , you are going to have to go over your hand a few times let it dry and go over it again ( try not to let it touch itself it will stick and then your going to have to start over, when it is a little dry but some baby powder or makeup sealer on it this will help so it wont stick to itself .once done you can paint over it with face/body paints .the paints with oil in them gives a better look, the water based ones dry better .
card stock
Q-tip
32 Comments
MiloFrangiPani 10 years ago
nogoodnikki 10 years ago
nogoodnikki 12 years ago
thansk again
flamingo123 12 years ago
bdoggy45 12 years ago
laurent123 12 years ago
yoshie257 12 years ago
killerx 12 years ago
ralph1e 13 years ago
happybuilder 13 years ago
seabananers 13 years ago
Apxeon 13 years ago
just2drops 13 years ago
you can try curing the latex once applied with diluted acetic acid or vinegar..(spraying works best, i used an old windex bottle)
the latex hardens and will become waterproof and wont tear that easily..
you could infact remove your webbed glove like a glove..
id also suggest adding another layer of latex on to the cured glove to strengthen it.
nice work.. brings back memories
bizshop 13 years ago
scoochmaroo 13 years ago
nogoodnikki 13 years ago
Garasvaldi 13 years ago
toad 13 years ago
