Introduction: Working 'digg Me' Tshirt Using the Digg Button Kit
Step 1: Introduction/Inspirations
I wanted a project that was related to digg, I can't exactly remember how I came up with a working 'digg me' tshirt, but it might have been while I was browsing the digg button kit and 'digg me' tshirt and I put two and two together.
Links to this project's inspiration:
digg me tshirt ( digg comments)
digg button kit ( digg comments)
It was noted that while writing this instructable digg user SnOwie mentioned he was working working on a shirt like this in the comments. This was purely coincidental; I would love to know how his is going.
I ordered the digg button kit from adafuit industries on the 30th June, so this project has taken approximately three and a half months to complete, working a few hours on the weekend.
Step 2: Research
The following is a list of resources that helped me greatly.
- Lame Lifesaver - Conductive Thread for Lame Repair
- A Wearable Display for Team Sports
- reSkin :: ANAT's wearable technology lab
- leah buechley - do it yourself - make your own wearable LED display
- GRYNX > Make your own wearable LED display
- DIGG button
0900766b80200898.pdf the Kingbright 1.5" 7-segment display
C4724JR.pdf the lighton triple digit 0.4" 7-segment display
Step 3: Materials/Equipment
- 1x large plain white Bonds tshirt, purchased from local department store $8.80
- 1x A4 sheet of iron-on transfer paper, eBay $3
- 3x 1.5" red 7-segment LED, SC15-11SRWARSAustralia $11.40
- 1x digg button kit US$23.20
- 1x spool conductive thread CAD$23.90
- 20cm nylon netting [http://nylon netting $8/m 20cm $1.60 Spotlight] $8/m $1.60
- 100x Sterling silver crimping beads 2mm eBay US$5
- rule
- scissors
- sewing machine
- pens
- iron and ironing board
- soldering iron
- wire cutters and strippers
Step 4: Prototyping
The digg button kit was assembled on a bread board with the 7-segment displays. The results are below:
Step 5: Designing the Digg Logo
The digg logo was constructed in Adobe Illustrator using the logo found on digg.com as a reference.
All colours were matched precisely and the gradients were quite close. The Adobe Illustrator files can be downloaded below. Feel free to use it in any of your digg projects in the future. Note, when applying iron-on transfers, the image needs to be reflected.
Step 6: Fabric Switch
I didn't have any conductive fabric, so the conductive thread was sewn to cover the fabric, two pieces of nylon netting was used to separate the fabric as this seemed to work the best.
Below is a video of the fabric switch in action:
Step 7: Sewing the Electrical 'tracks'
positives:
- greatly more wearable.
- interesting experience.
- very messy: whilst I planned where each thread would go, it was impossible to make nice stiches (as seen in the below photos).
- problem of shorts due to no insulation: whenever the thread needed to overlap, a piece of fabric was required to insulate the overlapping thread.
- visible: even though white thread was used on the outside and the conductive thread on the inside the almost black colour still showed through.
Step 8: Applying the Iron-on Transfer
Applying the iron-on transfer was quite straight forward.
The procedure is as follows:
1. print the design on the iron-on transfer paper with an ink-jet printer, the design must be reflected
2. trim any excess paper around the edges. Intricate detail can be left.
3. iron the tshirt to remove any creases, the iron should be on the driest setting.
4. apply the iron-on transfer to the tshirt facing down.
5. with a piece of fabric over the transfer, start ironing the iron-on transfer. The iron should be on the driest and hottest setting.
6. continue for 5 minutes. Remember to concentrate on the edges.
7. check that the transfer is stuck to the tshirt, if it can be removed continue ironing.
8. remove the backing paper of the iron-on transfer.
Step 9: Wiring (or Threading)
This was the most tedious part, and I was quite surprised when it worked straight away.
I used an idea I read on Leah Buechley's website where crimping beads were soldered to LEDs and then threaded with the conductive thread. The same principle was used here on both the 7-segment display and on the digg button PCB.
The 7-segment displays where glued together and all common anodes had soldered wires connecting them together.
It was determined that 4.0V was the optimal voltage (this was achieved by using a variable power supply and a multimeter). However, 4.0V batteries seemed to be quite a rarity. Hence, having owned a phone with a 3.7V battery, this was used instead and seamed to produce nice results. Phone batteries also have the advantage of being quite thin.
Step 10: Finishing It All Up
A piece of foam was placed around the 7-segment display with the idea to make it more comfortable to wear. After wearing the tshirt it was realised that the foam was too obvious and was attempted to be removed. The foam also made the 'digg me' print crinkled due to the glue.
The 7-segment displays had white faces, and ruined the yellow on the digg logo. Using a transparency and the liquid crystal display font, a logo was printed out with clear (white text) sections for the 7-segment displays.
45 Comments
12 years ago on Introduction
its cool but seems like a waste of time
14 years ago on Introduction
how about washing to t shirt ?
Reply 14 years ago on Introduction
I would make the electronics removable (with Velcro). Then I would just remove the electronics before washing it. A simple and elegant solution.
Reply 13 years ago on Introduction
that is a good idea. However, i would use a series of headers to be able to easily connect/disconnect the pcb from the kit... other than that, the displays, resistors, and other components used should not be affected by water. if the board from the kit is sewed into the shirt, though, at least remove the microcontroller before washing.
remove batteries,hand wash(NO MACHINE WASH),dry to the point it is dry as your computer,install batteries,VOILA
washing is the only problem, I don't wear it that often though. bit of Febreze maybe? :P
I digg this
How do i build the circuit in Step 4!??!?!?!
the circuit in step 4 is just the digg button kit.
schematic available here
anybody have a source of conduictive thread in the UK? I have a few ideas which require it, and cannot find it anywhere
http://members.shaw.ca/ubik/thread/order.html
ship internationally
thank you!
14 years ago on Step 10
really cool, just looks a bit complicated. you should try getting digg to sponsor you making and selling these shirts, id buy one
friggin awesome!anybody whos listening(technically reading)has got to try this
This is awesome. Sadly, I'm the only one in my offline circle who would even understand the joke.
Could you re-program it to do other things as well? Or does the kit come pre-programmed?
The kit comes pre-programmed. but yes, you could re-program to do other things.
This is a really great project. :) I like how its interactive, plus its an amazing conversation starter. What happens when the number reaches 999? Resets? Do you really think it belongs in the DIY Halloween though?
Thanks! Whilst I have never actually had it past 999, I am assuming it would reset, or you would need to manually reset it by holding down the button (a feature of the dig button kit) About the Halloween group, whilst it could possibly be classified as a costume. I thought I would add it to the group anyway.
you're pretty cool if you get that many diggs tho ;]
