滑板
Intro: 滑板
It's a combination of a balance car and a skateboard, combing the characteristics of these two tools, so a skateboard was born.
STEP 1: Build a Board First
Build a panel
STEP 2: Chamfer
Create a new entity merge, and then make a chamfer
STEP 3: Using the Method Described Above
Merge and chamfer both sides from the outside and inside at the same time.
STEP 4: Shear
To cut a cuboid at the center of the plate.
STEP 5: Do the Cylinderical
Close the panel and create a new cylinder.
STEP 6: Punching
Open the plate surface and test whether the cylinder is suitable in size. Then close the plate surface of the plate, center on the hole, cut a circle on each side, and build another circle around the hole to make a hole on the side.
STEP 7: Do the Tires
Close the plate surface, hole as the center, both sides cut a circle, hole as the center to build a circle.
STEP 8: Segmentation
Turn off the built plate wheel, another round cylinder built in the previous step, then pull out the gram, and then perfrom the partition entity.
STEP 9: Cut Off the Excess
Turn off the split bottom half to avoid grinding the wheels as they slide.
STEP 10: Connect the Overall
Create a new cylinder with the hole center as the origin and open all the plate and wheel can be connected.
STEP 11: Adjust the Scale
Adjust the legth and proportion of the plate to make it look more comfortable.
STEP 12: Chartlet
The adjustment completes, look sfor a piece of oneself like picture to stick up, the completion.
Penolopy Bulnick 4 years ago
