Introduction: IR LINE FOLLOWING ROBOT USING IR SENSOR ARRAY(8 INPUT) AND L293D MOTOR DRIVER
"My line following robot after making ,YOU can also make your own robot simply "
Step 1: Our Brain for Line Following Robot Is Arduino Nano
(its program methodology and pin configuration are same arduino uno (bcoz both contain Atmega328p) ,connect battery to VIN pin of aduino and take regulated 5v from 5v pin and it supply to IR SENSOR and motor driver's 16th pin
Step 2: IR Sensor Array
IR sensor array contain 8 IR LED and 8 IR SENSOR also it have two mode of output
1) analog output (direct analog data from ir sensor ) 2) digital output ( using linear voltage comparator with potentiometer)
Step 3: Motor Driver
Motor driver designed using L293D motor driver IC it give smooth operation and required fast output working together with arduino nano.
you can buy this module type of this ic from any market price will be less than 120 indian rupees
( or)
you can make your own board , i also attached the gerber file for making PCB board for L293D
GERBER FILE -DOWNLOAD HERE
Step 4: Gear Motors
100 RPM motors are used it this robot ,
Step 5: Battery for Line Following Robot
4 AA Battery used for running our robot , arduino nano have voltage regulator therefore it convert battery voltage into 5v give,this regulated 5v to motor driver's 16th pin for logic operation of motor driver ic L293D
Step 6: Wiring and Simulation ( Proteus Professional )
Microcontroller Contest 2017
