Introduction: +1-844-355-5111 20 Most Common PC Problems With Their Solutions
Eager to know about top most common problems of computer instead of their solution, read out this post completely or just make a call at +1-844-355-5111 for instant technical support related to all computers installation, setup, and upgrade/downgrade problems.
Error No.1
- Monitor LED is Blinking
- Solution: Check all the connections like Monitor Cable, Data cables, RAM, Display Card, CPU Connections etc.
Error No.2
- Continuous Three Beeps
- Solution: Problem in RAM Connection.
Error No.3
- Three Beeps (i.e. 1 long and 2 short)
- Solution: Problem in Display Card Connection
Error No.4
- Three long Beeps Period wise
- Solution: Problem in BIOS or RAM
Error No.5
- Continuous non-stop Beeping
- Solution: Key Board Problem (i.e. some key is pressed for longer time)
Error No.6
- NO display on the screen
- Solution: Hard Disk cable connected wrongly.
Error No.7
- Power led is off
- Solution: Check main power cord; check S.M.P.S; check motherboard connection
Error No.8
- Showing CMOS Error
- Solution: Replace 3 Volt Battery of motherboard; set original setting manually; enter your search form terms, submit search form
Error No.9
- Showing HDD error or Hard Disk Failure
- Solution: Check power cord; Check connection of HDD; Check Data Cable; Check Hard Disk parameters in CMOS or Auto detecting setting partitions by F-disk command, then format it to set track 0.
Error No.10
- Mother Board hangs due to un-stabilized power supply
- Solution: Check S.M.P.S; RAM not functioning properly; Software problem i.e. using pirated software; CPU fan not functioning properly
Error No.11
- Dancing Screen
- Solution: Check display card connection; virus problem; video memory problem
Error No.12
- Shaking Screen
- Solution: Earthing problem; Magnetic waves comes around
Error No.13
- CPU cabinet shock
- Solution: Check Earthing; Check main power cord
Error No.14
- Hard Disk making noise while processing
- Solution: Un-stabilized power supply; check for loose contact; do not use Y connectors for Hard Disk because it may create bad sector or weak Hard Disk.
Error No.15
- Hard Disk hangs while processing
- Solution: Check for bad sectors by using CHDISK or SCANDISK command. If found format the hard disk and set partition before that area. (Note: This is the only procedure to use hard disk with bad sector or to avoid bad sectors use standard power supply)
Error No.16
- Hard Disk not detected
- Solution: Check power connector; check Data cables; check jumpers
Error No.17
- Partition not shown
- Solution: Operating System where the Hard Disk formatted is not supported with present Mother Board
Error No.18
- Windows Registry error
- Solution: This will happen due to sudden ON/OFF of the system. Final solution is to Reinstall OS.
Error No.19
- Display color doesn’t match
- Solution: Configure Display Card properly or reset the setting
Error No.20
- Unknown Device found
- Solution: Driver Utility may not be provided with OS. For this install driver for the device.
