Introduction: Assassins Creed Hidden Blade
Step 1: Stuff You Need
2" three ring binder
Leather awl + heavy duty string
Two rivets
Coder pin
6" drawer slide (if you can't find them in stores
I got mine from a cabinet maker, he ordered mine for me)
Leather punch
Leather + fake/real fur
Two nuts from an erector set or from the hardware store
Step 2: The Support
Bend the binder rings open so they fit around your arm loose so that when we sew the tearjerker in it will be snug then take the drawer slide and mark where you will put rivets in to hold it on then cut off the front and back portion of the binder so it wonk hurt your arm
Step 3: Connecting the Drawer Slide
Bend the holders on the drawer slides so they fit close to the binder then rivet through the holes. I have found that if you put a small nut on the end of the rivet it holds it on better
Step 4: The Leather
If you don't have a sheet of leather big e ought to fit around your binder clip then you can do what I did and sew the leather together to form a large sheet.then wrap the leather around the binder and mark where you want the leather and cut it. Then use leather rivets to make the leather tight. Then you can put fake or real fur on the inside to make the fit tighter and it looks cool
Step 5: The Lock Mechanism
Bend the cotter pin so it looks like this. You could put a spring instead of a rubber band but whatever works.
Metal Contest
Epilog Challenge VI
