Introduction: Bedroom Shelves
Hello Everyone
This instructable came very slick and neat !
I have a spare room @ my home, and one of it`s walls is empty ( beside a big picture )
So i decided to remove the pic, and build two big shelves that can host many many books, art, a bunch of stuff.
The building process took one week or so , had to buy the wood, saw it, adjust the height, and finally hang it.
Came very nice!
Enjoy
Step 1: Cut the Wood
Soo, first step would be to cut all wood that i bought according to my desired size.
I measured the wall and fitted it with the shelves .
But i didn't want the shelves to be regular fitted, but rather to be in a different height each.
So i had to cut each angle on the side and fit it
Step 2: Screw Them Together
Screw each wood to each other
The sides we will grind later and fill it with wood filler
Step 3: Wood Filler
Fill the gaps with the wood filler , let it dry for a few hours and than we will sand it
Step 4: Sanding Time
Sand all the edges .
We need it to be smooth as silk !
Step 5: Install Rods on Wall
This was a tricky one.
I needed to hold the shelves alone , mark the height and drill.
Soo it took some time.\
Step 6: Place It on the Aluminum Rods
Check with a leveler if all is good , if yes continue to paint it
Step 7: Paint It!
Now the painting of the wood.
I used a sponge in order to give it a slick look ( a bit grindy )
Came great !
Step 8: Prepare Rods for the Sides of the Shelves
In order to prevent the books from falling, i prepared aluminum rods and wood pieces attached together.
Step 9: Continue With Installation
Drilled the shelves at the spot i marked.
Painted the sides of the stoppers in black color
Step 10: Install Shelves
installed the shelves.
Painted yellow the sides of it - looks much better
Step 11: Finally Finished
Came out cool !
