Introduction: DIY Cup Garden
I've started indoor gardening and I must say, it's really addictive! But what's fun in putting all the plants in plain pots? So I decided to make a cup garden. I've been wanting to make a fairy garden for a long time but made something quite similar this time. Might try to make a fairy garden next time.
Best thing about this cup garden is that I used cactus, succulent and wall plants, which require very low water and care. You can take it outside easily for a little sunlight and it's a great candy to the eye!
I'll take you step by step to making a cup garden of your own.
Check out the ible!
Step 1: Materials Needed
To make this cup garden you'll need:
- Old cup and saucer
- Small rocks and mixed soil
- Cactus and succulents
- Wall moss and plants
- Wooden crafts sticks or twigs
- Craft glue or hot glue gun
- X-acto knife and cutting pliers
- Ruler and pencil
Mosaic stones
Step 2: Collecting the Pot
You can use any kind of pot you want but lets try something different.
I'm using an old cup and saucer for my mini garden. You can drill a hole at the bottom of the cup for drainage or use another technique, check out the next step to find out.
The size of the cup would depend on the number and size of the plats and accessories you'll be using. The one I used wasn't too big nor too small, worked out perfect!
Step 3: Preparing the Pot
Gather some small rocks and mixed soil, do not use sand,
Fill the bottom of the cup with the small rocks. Fill one third of the cup with rocks.
Now fill the rest of the cup with the mixed soil. Keep the soil level a cm below the edge of the cup.
Keep the pot aside and lets create the accessories.
Step 4: DIY Mini Garden Accessories
I'm using wooden craft sticks to make a mini bench, ladder and fence. While you're making the accessories keep in mind that the sizes of the accessories should be proportionate to the cup size and plants.
Use cutting pliers or x-acto knife to cut the sticks.
Measure the height of the cup, add 2 cm to that and cut 2 sticks of that size. These are the side rails of the ladder. Cut the rungs as many as you need to make the ladder, I had to cut 6 pieces. Now place the side rails on a flat surface and simply glue the ring pieces on them. Allow the glue to dry.
For the bench you'll need to prepare sticks for the legs, seat and back side. I used 4 pieces for the seat, 4 pieces for the legs and 5 pieces for the back. Cut a small piece of paper and glue the 4 sticks for the seats on it. Now turn it over and glue the 4 leg pieces on 4 corners. Finally make the back and glue it to complete the bench.
I made a tiny fence so so didn't need to cut many sticks. For the fence cut 4-6 small sticks, keeping 2 cm extra with the required height. Place the sticks on a flat surface vertically by keeping even gap between them. Glue another stick on them horizontally and allow the glue to dry.
You can make so many tiny things with these sticks. You may also try making a swing, stool, table, cabin, mail box, birds house and much more.
Step 5: Collecting Plants
Collecting the plants for this garden is really easy. Collect or buy small cactus and succulent plants. These plants require very low water and nurture. If you plants small cactus and succulent plants it'll take years for them to grow.
Besides you can also use wall moss, ferns and other plants, they also require less water and nurture.
Step 6: Checking All the Items
Prepared the pot (cup), made the mini stuffs, collected the plants and also gathered a few more stuffs for decoration. I'm going to place small mosaic stones, clay mushrooms, super tiny snail shells for the decoration.
Once you've collected and prepared everything for the cup garden decide how you want to decorate and place things.
Step 7: Planting
Planting these plants are super easy because they don't have huge roots so you don't have to worry messing the top soil.
Use a small stick or your finger to make a hole on the soil, place 2 cm of the plant in the hole from the bottom, fill the rest of the hole with soil. Plant the other cactus and succulents similarly. Try keeping small gaps between each plant and also keep at least a cm of gap between the plants and the cup's edge.
Step 8: Decorating
Lucky me, I found a piece of small flat concrete, just the perfect size and shape. I placed it beside the plants so that I can put the bench on it. You'll need to glue the bench on that concrete piece.
Try too collect vine type small wall ferns, I have loads of them on the walls of my garden. Take a long piece of the wall plant. Push its root in the soil near the cups edge, in front. Now glue the cup on the saucer and then glue the ladder with the cup and the saucer, so that we can climb to the garden from the saucer! Wrap the wall plant around the ladder carefully.
Placed some wall moss beside the concrete piece and filled the rest of the soil top with small flat mosaic stones. Also placed the small snail shells near the plants.
Step 9: Final Touch!
The saucer seemed empty and boring so I placed some mosaic stones around it and glued 2 small clay mushrooms near the ladder.
Thanks for checking out my ible and please do try to make one if you're inspired! Share a picture if you make one :)
Ahh, I'm happy with how this turned out!
Enjoy!
Runner Up in the
Summer Fun Contest 2016
Runner Up in the
Low Water Gardening Challenge 2016
Trash to Treasure Challenge
