Introduction: DIY EGG NIGHT LAMP
MAKE YOUR VERY OWN NIGHT LAMP W/ AN EGG.
like and share
Step 1: MATERIALS:
1. Egg shell
2. Yellow diffused LED
3. Switch
4. Ready made LED case
( You can make your own) look at picture, that kind of case.
5. Lithium cell battery 3V
TOOLS:
solder
gluegun
Step 2: Insert the LED
insert the LED and the battery, make sure the Anode is touching the positive of the battery.
Step 3: CONNECT
connect the Cathode to the left pin of the switch.
Then, connect middle+right pin of switch to the negative side of the battery.
Step 4: TEST IT OUT!
on the switch to test it out. If it works, go to the next step.
Step 5: GLUE THE EGG SHELL.
Glue gun the egg shell to the LED make sure the hole is big enough for the LED to go through.
Step 6: Draw on It
use a marker, draw any design you want.
Step 7: You Are Finished.
Like share and subscribe for more new easy diy projects.
