Introduction: Drill Press Table
Nine times out of ten, you don’t need a drill press table but it sure would be nice for that one time. Because it’s use is so limited I wanted to keep the design/build simple, no frills. Also mounting needed to be quick and easy.
Step 1: Table Material:
The table itself well be two pieces of ¾” plywood laminated together. I just so happen to have some scrap plywood already doubled up in the shop from a pervious project so it was just a matter of cutting out a 15” by 18” rectangle on the table saw. The size is really just personal taste, I just wanted something as small as I could get away with to make it easy to store away.
Step 2: Table Mounting
To mount the homemade table to the drill press table as easy as possible I decided to make a ¼” deep recess the exact same size as my drill press table. This should keep the table from moving around from left to right. I used my CNC router to do this because my two pieces of plywood were already laminated together but you could cut the circle out with a jig saw before laminating the two pieces together.
Step 3: Installing Keys
To keep the table from rotating I decided to make a couple of keys the same size as the slots in my drill press table I then could glue and screw them right to the under side of my homemade table.
Step 4: Edge Banding
To clean up the edges, I used some ¾” maple for edge banding.
Step 5: Adding T-track
I then could cut two dados for some T-track. This will be used for the fence as well as hold down clamps if needed. I installed the T track using screws.
Step 6: Waste Insert
I then cut out a 3/16” deep recess using my dado stack right in the middle of my table. The recess is 3” wide and will be use for a MDF waste insert.
Step 7: Making Inserts
I already had a bunch of scrap MDF so I went ahead and cut a whole bunch of inserts by ripping them 3" wide making sure they are a tight fit in the recess.
Step 8: Fence
he fence couldn’t be easier, its just two pieces of ¾” plywood laminated together and cut to 2” wide. I then could mark the location of my T-tracks and drill corresponding holes.
Step 9: Stop Block
You could also add some T-track on the fence front if you want, I didn’t have any left and didn’t really feel it was necessary as I could just clamp a block onto the fence for a stop.
Step 10: Adding Chamfer
Finally i added a chamfer to the back so I can still rise the table without hitting my knuckles:)
Probably the best feature about this table is how easy it is to take on and off. I love how quick and easy it was to build and also how easy it is to store away when not in use.
