Introduction: Green Gouge Ball Shou Sugi Ban
A few months ago I posted some wooden wall art panels with a unique abalone effect that I discovered by mistake. This post has become one of my most popular posts because it was so unique. I had so many compliments on this wall art but I also got a few comments saying that it looks too hard. While I personally found them easy to make the process is very time-consuming. Today I will share how I cut my work time in half by using a gouge ball to create this Shou sugi ban wall art.
Step 1: Original Project
This image was the outcome of the original project where I discovered this technique. I used a wood router to add the grooves into the wood and spent hours removing the square edges left by the router. Over the years I have done a few Shou Sugi ban projects and know if I burn the wood deep enough it is easier to sand. I got so bored spending hours sanding the grooves I thought I would try and burn the sides to speed up the process. The abalone effect you see was the result, I did call it snakeskin-effect at first but I think it looks more like an abalone shell. A project like this can take a few days to complete so when I saw a gouge ball on Pinterest I was hoping it would work for this project
What is Shou Sugi Ban?
Originating in 18th century Japan, Shou sugi ban is a particularly striking method of preserving wood by charring it with fire. Traditionally, this practice is used with Japanese cedar in order to weatherproof it. The wood is burned until the surface is charred, and then coated with natural oil. The result is a scorched finish with a magnificent charcoal black colour. The surface of the wood can take on a crackled or alligator skin look depending on the wood species and the burning intensity. Traditionalist utilizes only Cryptomeria japonica or Japanese cedar because it can take the heat for a deep burn resulting in pest, rot, and fire-resistant as well as becoming a natural water repellent and sun shield. While this is the traditional method, over the years people have played around with it and this post will show another great way to use Shou Sugi Ban.
Step 2: Gouge Ball
The video I saw on Pinterest using the gouge ball was a guy making wooden spoons. He used the gouge ball to create the groove in the wooden spoon, so I believed it would work to create the groove in my wall art.
I did a search on the internet and found two variations of the gouge ball. The first one was by a company called Arbortech with a price of around $120.00 and the second gouge ball looked different with a price of under $30. Because I was unsure if this would work I went for the cheaper option, which worked perfectly for this project. The gouge ball is an attachment that fits onto an angle grinder. I bought the 40mm ball for this project.
Step 3: Find Suitable Wood
For this project, I used some recycled pine from an old bed frame. I prefer to use pine because the wood is softer and I have found I get more dramatic results.
Start by clamping your piece of wood to the table surface. The grinder with the gouge ball is very powerful and will cause the wood to fly off the surface. Yes, I learned that the hard way. To add the groove it is as simple as moving the gouge ball across the surface. I did a couple of passes to get my grooves deeper. The surface was not very smooth after the groove was added but once the wood is burnt it will be smoothed out.
In hindsight, I think the grooves would have looked nicer if they were running in one line across each panel. But hey-ho we live and learn.
Step 4: Burning the Wood
To burn the wood you will need a blowtorch. Using the blow torch you burn the surface until the top layer of wood is cracked and charred.
Step 5: Sanding the Wood
To sand, the charred surface you have two options that I use. You can use a wire brush and rub it with the grain of the wood until you see the light wood coming through. This is very time-consuming and will take a few hours.
Another option is to use a coarse nylon brush that can attach to your drill. This is the fastest way I have found and cuts your sanding time in half. The brush is held over the surface sanding with the grain. You will notice the great texture on the surface after this step. If you want more texture you can burn the wood again and sand deeper into the surface.
To create the multicoloured look you need to sand some areas deeper than others. The more you sand the lighter the wood will become and the more vibrant the colour will be. If you leave some areas darker like the images below the results will be more dramatic. You will also notice that the woodgrains and the knots will stay black and raised.
Step 6: Adding Oil to the Wood
If you prefer the plain wood colour you can stop now and add some oil to protect the surface. This will also deepen the colour of the wood.
I made these panels to decorate my porch, but unfortunately, they blended in with the bricks and I thought the effects were lost. So I changed my mind and went ahead and painted them.
Step 7: Painting the Wood
There are a few ways to paint Shou Sugi Ban. I did a few tests a while back trying different products and shared the results in this post. When adding paint to the raw wood you will need to wet the surface first to prevent the staining as I got in the image below.
I did not need to do this because I had already added the oil. To stain this wood I used regular indoor house paint.
To apply the paint I used a paint roller and added a thick layer to the surface and let it soak in for about 5 minutes.
I used a clean rag to wipe off the excess paint. You can repeat this step if you want a darker colour.
I left the paint to dry before adding some more oil to seal the surface. While I only added one colour to these panels, the different depths the wood was sanded created the other colours. While I added blue paint to the wood, I ended up with a green colour after I added another layer of oil to the surface.
Step 8: Final Product
I have added some close-up images so you can get a better look at the effects of the shou sugi ban.
Step 9: More Shou Sugi Ban Projects
I created this Shou Sugi Ban wall hanging using scraps of assorted wood and painting the surface.
Step 10: How to Add Colour to Shou Sugi Ban
This post will show you how to colour Shou Sugi Ban. I used a variety of different products and showed the results of each.
You can find more unique ideas on my website Unique creations by Anita
Colors of the Rainbow Contest
