Introduction: Head on a Platter
step one.. take 2 x 10 planks cutting them 1' 9" and 2 pieces 3' 10 1/2 "
step two cut 5/8th piece of plywood 4' x 2' cutting 1 1/2 squares out of each corner.
step three make three cornered box leave spaces in corners for legs.
step 4 cut another piece of plywood 4' x 2' cutting hole in center big enough for your head.
step 5 cut 2 x 4 plywood and add swivel 4" wheels to front and solid 4' wheels to back.
add bolsters or just 2x2's as legs connecting your table together.
step 6 cut a piece of 1/4 " plywood so that it fits compfortably down your back with a nice sized base level with the middle of your buttocks.. attach a 1 in pipe welded to a 4' by 4' steel base 1/4 " sheet steel, to center of plywood base above buttocks. add padding where needed.
step 7 make phony body with foam rubber leaving center hollow add foam head and a mask either store bought or create your own but I will not get into that buy one if you have never worked with foam latex.
mount the head onto a piece of pipe smaller than the piece on plywood base and drill a hole 1/2 " higher than the base pipe mounted to plywood base that goes above buttocks, and slide a bar through that hole l not protrude past phony body sides put head on pipe and slide pipe through the phoney body add cross bar through pipe..
step 8 clothe body and add gloves & phony hands .
step 9 cut serving tray in half and a hole big enough for you neck on one side
step 10 hook two rods one to each end of the rod through the pipe about three ft long.( this is so you can control turning the head.)
step 10 cut table cloth to fit cutting hole in center.
step 11 secure plywood to body and slide into the box putting head through the hole.
step 12 have helper adjust fake body in pipe slot ,fasten hand to table, slide tray under chin and ajust
step 13 FREAK everyone out walking around and partying.
Step 1:
Step 2:
Step 3:
Halloween Costume Contest
Halloween Props Contest
