Introduction: How to Convert PDF to Word for Easy Editing
Have you ever wanted to edit a PDF file? For example, there are some obvious typos mistakes that need correction or you need to add some text to the file or even change the entire layout. But it’s difficult to achieve even if we just want to make thumbnail redaction in a PDF document.
PDF file is no more than an export file, in other words, it’s not strange that it has non-editable feature to keep files exactly as original when displayed or distributed and of course it’s a liked feature at most of time.
But like some examples which I take at beginning of the article, editing a PDF is strong demand so that we may want to convert PDF to Word for easy editing.
Because we are quite familiar with editing in a Word document and there are many tools and functions for us to rearrange a file.
So if we can convert PDF to edit in Word, it will be an easy task for us. And it will be a plus that a method can cope with encrypted PDF files.
Usually a quick Google shot will reveal you many PDF to Word Converters. For urgent PDF to Word editing, you may have tried some of them and so I am no exception.
As far as I concerned, a good PDF to Word Converter should have below features to convert PDF for editing in Word:
It should have an intelligent converting ability- well retain the content like text, graphics, diagram, layout, etc of original PDF file.
It needs to convert PDF to Word file in an efficient way- converting in batch or partial and some convenient presetting to take care of easy manipulation.
It does will be liked if it can remove permission password that restricted us to edit a PDF file by itself. In this case you can also use it as a PDF unlocker.
If you don’t have access to web, it will also convert PDF to Word for easy editing of you. And it should have no any unsafe issue for your confidential files.
To conclude from above features, I recommend you to find a desktop PDF to Word Converter.
Then I want to show you the simple manipulations of it to convert PDF to Word for easy editing:
Free download PDF to Word Converter then install and open it.
Step one: Loading you files into the converting panel by “Add Files” or “Add Folder”
Step two: Specify the output format to Word and certain page ranges if necessary. Don’t forget to customize an output folder path.
Step three: “Convert” them instantly to Word documents and when completed it will auto leads you to output files.
Isn’t it what you want? I think a good PDF to Word Converter will simplify everything for you.
Somthing more about you can do to convert PDF to editable Word , actually you can also use a PDF editor to directly edit in a PDF file.
