Introduction: How to Recover Deleted Files From the Recycle Bin in Windows OS
Step 1:
1. Download Pandora File Recovery http://www.pandorarecovery.com/download/
Step 2:
2.Run and Install Pandora Recovery Setup.
Step 3:
Step 4:
3.Follow the Pandora Recovery Wizard for first time use.
Step 5:
3a. Use the wizard to find the deleted file in the recycle bin and follow the instruction to restore it in the recycle bin
Step 6:
Step 7:
3b. If not found in the recycle bin, it asks the user where was the file was last seen.(Default is Drive C:)
Step 8:
3b-1. Choose an option what best suits your search type for
Step 9:
3b-2. Select file type to be searched for and choose which disk drive to search in. Press "Start Disk Surface Scan"
Step 10:
3b-3. When desired file is found, right click and "recover to".
Step 11:
3b-4. Choose a desired location to where it will be restored to, then click "Restore Now". (Preferably save it into
different drive to where it was originally saved.)
Step 12:
3b-5. A popup window will appear once it restores successfully.
Step 13:
3b-6. After pressing close in the pop up window, the location where the file was restored to will pop out and you can check
the file restored.
