#include |
#include |
#include |
#define LCD_pin 5 // LCD data signal |
const int NoDetect=30; |
int counter; |
int NumDisturber=0; |
SoftwareSerial LCD = SoftwareSerial(0, LCD_pin); |
void printAS3935Registers(); |
// Function prototype that provides SPI transfer and is passed to |
// AS3935 to be used from within library, it is defined later in main sketch. |
// That is up to user to deal with specific implementation of SPI |
// Note that AS3935 library requires this function to have exactly this signature |
// and it can not be member function of any C++ class, which happens |
// to be almost any Arduino library |
// Please make sure your implementation of choice does not deal with CS pin, |
// library takes care about it on it's own |
byte SPItransfer(byte sendByte); |
// tunecap is needed to display the calibration register value |
int tunecap; |
// Iterrupt handler for AS3935 irqs |
// and flag variable that indicates interrupt has been triggered |
// Variables that get changed in interrupt routines need to be declared volatile |
// otherwise compiler can optimize them away, assuming they never get changed |
void AS3935Irq(); |
// volatile int AS3935IrqTriggered; - not needed anymore |
// First parameter - SPI transfer function, second - Arduino pin used for CS |
// and finally third argument - Arduino pin used for IRQ |
// It is good idea to chose pin that has interrupts attached, that way one can use |
// attachInterrupt in sketch to detect interrupt |
// Library internally polls this pin when doing calibration, so being an interrupt pin |
// is not a requirement |
AS3935 AS3935(SPItransfer,3,2); //change to AS3935(SPITransfer,9,3) if using slot #2 |
// AS3935 AS3935(SPItransfer,77,26); //if using Flip & Click socket A |
void setup() |
serLCDInit(); |
backlightOn(); |
clearLCD(); |
lcdPosition(0,3); |
delay(3000); |
LCD.print("Rivelatore"); |
delay(2000); |
clearLCD(); |
lcdPosition(0,0); |
LCD.print("Di Fulmini"); |
delay(2000); |
clearLCD(); |
lcdPosition(0,0); |
LCD.print("G.Carneglia"); |
delay(1500); |
clearLCD(); |
pinMode(7,OUTPUT); |
pinMode(8,OUTPUT); |
Serial.begin(9600); |
// first begin, then set parameters |
SPI.begin(); |
// NB! chip uses SPI MODE1 |
SPI.setDataMode(SPI_MODE1); |
// NB! max SPI clock speed that chip supports is 2MHz, |
// but never use 500kHz, because that will cause interference |
// to lightning detection circuit |
SPI.setClockDivider(SPI_CLOCK_DIV16); |
// and chip is MSB first |
SPI.setBitOrder(MSBFIRST); |
// reset all internal register values to defaults |
AS3935.reset(); |
delay(10); |
AS3935.setIndoors(); |
AS3935.registerWrite(AS3935_NF_LEV,2); //write 2 in the Noise Level register |
//AS3935.registerWrite(AS3935_SREJ,0); //write 2 in the Noise Level register |
// and run calibration |
// if lightning detector can not tune tank circuit to required tolerance, |
// calibration function will return false |
if(!AS3935.calibrate()) |
Serial.println("Controllare il dispositivo1"); |
// now we print the value in the calibration register TUN_CAP |
// it is in the range 0 - 15 |
tunecap=AS3935.registerRead(AS3935_TUN_CAP); //Internal calibration |
Serial.print("Il Reg. tuningcap e' "); |
Serial.println(tunecap); |
// since this is demo code, we just go on minding our own business and ignore the fact that someone divided by zero |
// first let's turn on disturber indication and print some register values from AS3935 |
// tell AS3935 we are indoors, for outdoors use setOutdoors() function |
// AS3935.setOutdoors(); |
// turn on indication of distrubers, once you have AS3935 all tuned, you can turn those off with disableDisturbers() |
AS3935.enableDisturbers(); |
// AS3935IrqTriggered = 0; |
// Using interrupts means you do not have to check for pin being set continiously, chip does that for you and |
// notifies your code |
// demo is written and tested on ChipKit MAX32, irq pin is connected to max32 pin 2, that corresponds to interrupt 1 |
// look up what pins can be used as interrupts on your specific board and how pins map to int numbers |
// ChipKit Max32 - irq connected to pin 2, or Arduino with irq connected to pin 3 |
// Uncomment the next line if using slot #2 of the Arduino mikroBUS adapter |
// attachInterrupt(1,AS3935Irq,RISING); |
// uncomment line below and comment out line above for Arduino Mega 2560, irq still connected to pin 2 |
attachInterrupt(0,AS3935Irq,RISING); |
// attachInterrupt(digitalPinToInterrupt(26),AS3935Irq,RISING); // if using Flip & Click socket A |
void loop() |
// here we go into loop checking if interrupt has been triggered, which kind of defeats |
// the whole purpose of interrupts, but in real life you could put your chip to sleep |
// and lower power consumption or do other nifty things |
// I prefer to move this code inside the interrupt routine itself |
// Here I leave only some code to display "Waiting..." so I know everything works |
delay(1000); |
Serial.println("In attesa..."); |
if (counter==0) |
NumDisturber=0; |
counter=NoDetect; |
clearLCD(); |
lcdPosition(0,1); |
LCD.print("Nessun Fulmine"); |
lcdPosition(1,4); |
LCD.print("Rilevato"); |
Serial.println("nessun fulmine rilevato"); |
else |
counter=counter - 1; |
void printAS3935Registers() |
int noiseFloor = AS3935.getNoiseFloor(); |
int spikeRejection = AS3935.getSpikeRejection(); |
int watchdogThreshold = AS3935.getWatchdogThreshold(); |
Serial.print("Rumore di Fondo: "); |
Serial.println(noiseFloor,DEC); |
Serial.print("lo Spike Rejection e': "); |
Serial.println(spikeRejection,DEC); |
Serial.print("Il Watchdog Threshold e': "); |
Serial.println(watchdogThreshold,DEC); |
// this is implementation of SPI transfer that gets passed to AS3935 |
// you can (hopefully) wrap any SPI implementation in this |
byte SPItransfer(byte sendByte) |
return SPI.transfer(sendByte); |
// this is irq handler for AS3935 interrupts, has to return void and take no arguments |
// always make code in interrupt handlers fast and short |
void AS3935Irq() |
// there is no need for this flag anymore |
// AS3935IrqTriggered = 1; |
// I move all the code for dysplaiying events inside the interrupt routine |
// again there is no need for this flag |
// reset the flag |
// first step is to find out what caused interrupt |
// as soon as we read interrupt cause register, irq pin goes low |
int irqSource = AS3935.interruptSource(); |
// returned value is bitmap field, bit 0 - noise level too high, bit 2 - disturber detected, and finally bit 3 - lightning! |
if (irqSource & 0b0001) |
Serial.println("Rumore Elevato, settare il rumore di fondo"); |
if (irqSource & 0b0100) |
NumDisturber+=1; |
Serial.println("Scarica Rilevata"); |
clearLCD(); |
lcdPosition(0,0); |
LCD.print("Scar. Ril: "); |
LCD.print(NumDisturber,DEC); |
Serial.println("Scar. Ril"); |
Serial.println(NumDisturber,DEC); |
digitalWrite(7,HIGH); |
delay(1000); |
digitalWrite(7,LOW); |
counter=NoDetect; |
if (irqSource & 0b1000) |
// need to find how far that lightning stroke, function returns approximate distance in kilometers, |
// where value 1 represents storm in detector's near victinity, and 63 - very distant, out of range stroke |
// everything in between is just distance in kilometers |
int strokeDistance = AS3935.lightningDistanceKm(); |
if (strokeDistance == 1) |
Serial.println("Tempesta, Attenzione!"); |
lcdPosition(1,1); |
Serial.println("PERICOlO!!"); |
lcdPosition(1,3); |
Serial.println("ALLONTANARSI!"); |
counter=NoDetect; |
digitalWrite(8,HIGH); |
delay(3000); |
digitalWrite(8,LOW); |
if (strokeDistance == 63) |
Serial.println("Fulmini Lontani."); |
lcdPosition(0,2); |
Serial.println("Fulmini"); |
lcdPosition(1,0); |
Serial.println("Oltre Portata"); |
counter=NoDetect; |
if (strokeDistance < 63 && strokeDistance > 1) |
Serial.print("Fulmine Rilevato a "); |
Serial.print(strokeDistance,DEC); |
Serial.println("Kilometri"); |
lcdPosition(1,0); |
LCD.print("Distanza:"); |
LCD.print(strokeDistance,DEC); |
LCD.print("km"); |
counter=NoDetect; |
