Introduction: Jibaro Headdress
This instructable will show you how to make a head dress piece based on the episode "Jibaro" from Netflix's Love Death Robots.
You will need:
1 Empty and clean gallon plastic milk jug
1 Wide Headband
1 Narrow Headband
*Hot Glue and Hot Glue Gun* - Use Safety
Assorted costume jewelry including pearls.
Wide gold ribbon
Wide coin-embellished ribbon or belly dancer shawl.
Beads on a string ( Various Lengths 12"-18")
Stripped headband
Scissors
*Utility Knife* - Use Safety
Beading Wire
Needle and Thread
Marker
Styrofoam Mannequin Head
Optional: Black Bob wig, Jewelry Glue, Fabric Glue
Step 1: Base
The base structure is made of the plastic milk jug. You'll want to mark where you'll be cutting to make the shape of the headdress. It kind of ends up being bonnet shaped. You can always trim as needed.
After the shape is cut. Find the where the center would be by placing it on the mannequin head. Trim as needed until you're satisfied with the over all shape.
If you find the shape is a little too square at the top of the bonnet, you can pinch the plastic underneath and hot glue in place to make a more round shape.
Step 2: Attach Base to Band
Align your headband and mark where it will be lying under the plastic base. Carefully make slits on those marks with a utility knife. Use beading wire to hold the head band in place and tie off the ends. For extra hold you can use some dabs of hot glue between the headband and plastic.
Step 3: Covering
Cut the seams on your headband and drape over the base while it's on the mannequin head. You'll want the stripes going across your head (ear to ear). Trim if needed and tuck cloth under plastic base and secure with hot glue.
Step 4: Add Embellishments
This part is where it really starts looking fancy. I started with a length of a wide gold ribbon and cut it to length so there was some extra hanging on each side. You can cut parts of an old belly dancer shawl to have beads already sewn in a line or you can probably find something similar on a spool at a craft supply store.
I did not string any beads. You can buy already stringed beads or Mardi Gras beads would work too. To attach the strings of beads take your original wide gold ribbon and hot glue it under to form a loop this will be a loop you can pass the beads through. Then take thread and tighten that area so the bead strings stay in place. When worn, the beads will lay under your face.
You can continue to add little gold coins, jewelry and gems on the headband to your liking.
Step 5: Second Headband
To add the big pearls on the sides of the headdress, I hot glued an old fake pearl bracelet to each side of the skinny headband. Use the base of the bracelet for a secure hold and for extra strength wrap and tie thread around. They will hang nicely like a cluster of pearls.
Step 6: Wear and Enjoy
Have fun with your headdress. Complete the look with the siren's make up.
Halloween Contest
