Introduction: Jupyter Notebook on Raspberry Pi
About: I am a keen IoT inventor as a hobbyist in Sydney and very passionate about IoT and Algorithms such as MACHINE LEARNING, COMPUTATIONAL STATISTICS and so on. Also, I have spent almost every day of the past 15 ye…
About Jupyter Notebook
The Jupyter Notebook is an open-source web application that allows you to create and share documents that contain live code, equations, visualizations and explanatory text. Uses include: data cleaning and transformation, numerical simulation, statistical modeling, machine learning and much more.
Step 1: Installation
Type the following into the terminal:
sudo su -
apt-get update
apt-get install python3-matplotlib
apt-get install python3-scipy
pip3 install --upgrade pip
reboot
sudo pip3 install jupyter
The Raspberry Pi normally uses an memory card, called an SD card, just like the ones you might use in your digital camera. They don’t have as much space as a normal computer. Issue the following command to clean up the software packages that were downloaded in order to update your Raspberry Pi.
sudo apt-get clean
Recent versions of Raspian replaced the Epiphany web browser with Chromium (an open source version of the popular Chrome browser). Epiphany is much lighter than the heavier Chromium and works better with the tiny Raspberry Pi Zero. To set it as the default browser to be used later for the IPython notebooks issue the following command:
sudo update-alternatives --config x-www-browser
sudo reboot
Step 2: Testing
Start IPython by issuing the following command from the Terminal:
jupyter-notebook
