Introduction: Listerine SD Card Holder
In This Instructable, I will show you how to make a Hidden SD card holder from a used Listerine Breath Strips case.
For this project, you will need:
A used Listerine Breath Strips PocketPak
1 or 2 Full sized SD cards
A piece of paper The color of the case ( I used green construction paper)
*Optional* A few breath strips
Step 1: Step 1
Place the two SD cards on top of each other inside the case. Two of the cards should fit in the case perfectly. You can put one card but you will need some kind of a spacer to keep the card in place... maybe some breathstrips???
Step 2: Step 2
Now put the strip of green paper on top of the SD cards. Then put the top of the case on. It may be a little hard to keep the paper in place as you put the top, but you'll get the hang of it after a couple of times. Now the top should be on with the paper covering it.
Step 3: Step 3
Now your done! Your SD cards should sit snugly in place with the paper covering it and look like one that has breath strips. The maximum storage capacity can be 128 GB if you manage to find two of Toshiba's 64 GB cards. Please leave comments and rate me.
* I'm working on one using microSD cards*
