Introduction: Machinist Vise Stop... ( Clamps on Jaw )
These are directions on how and what you need to make your own vise stop
for a kurt style vise...
I did it at the Tech Shop in San Jose California....
http://techshop.ws/
Gabriel Aceves....
Step 1: Step One... Materials and Tools...
You are going to need one piece of .625 x 1.50 x 1.125 inch steel bar stock... One .500 inch endmill capable of cutting steel...
A .159 inch drill bit... 10-32 cut tap... Two 1.0 inch long 10-32 cap screws... One Tap Handle...
A milling machine... .5 inch collet ... Mill drill chuck attachment... I included a rude handdrawn print in the pictures...
Step 2: Step Two... Blanking Your Material...
So you are going to want to start out with .625 x 1.50 cold rolled steel bar stock and cut off
a piece that is 1.125 inches long.... Deburr your cut edges so they
do not get in the way later... You may want to cut a few extras, stuff happens...
Step 3: Step Three... Squaring Up Your Material...
Now we are going to start cutting our parts with the milling machine.....
We are going to use two of the stock dimensions and only alter the 1.125 dimension...
First you are going to make a side cut to square up one edge...
Remove about .05 inch or so from one side as shown in the picture...
next you are going to flip your part with the other saw cut edge facing up and cut it down using the tip of the endmill...
Until you reach your finished dimension of 1.00 inches... Make sure everything is square because this
is a tool and you always want your tools to be perfect because your finished product can only be as good
as the tools used to produce it...!!! Dont forget to deburr your newly formed burrs...!!!
Step 4: Step Four... Cutting the Slot...
Now we are going to cut a slot in our part as shown to the dimensions listed... Again it is of utmost importance that everything is square and parallel.... Your slot does not need to be perfect... So if you are .02 or .03 to big or
to deep dont worry your stop will still function... just keep it square...
Step 5: Step Five... Drilling...
Now we are going to drill our .159 pilot holes for our 10-32 tapped holes in the locations shown... Locations of these holes
are some what important so try to get them as close to the dimensions shown....
Step 6: Step Six... Tapping Our Hole...
Now we are going to tap our 10-32 holes... Try to get good quality holes because these screws are going to be
loosened and tightened often... Use cutting oil...!!!
Step 7: Step Seven... Assembly...
Now we are going to screw our 10-32 cap screws in to the tapped holes as shown and now you have a new
vise stop... I did this at the the Tech Shop in San Jose California... Gabriel Aceves
