Introduction: Over Band Magnetic Seperator
Electro Flux Over Band Magnetic Seperator are designed for installation over conveyors where tramp iron contamination exists and needs to be removed for protection of subsequent processing machinery or providing cleaner product. The self-cleaning type uses a two-pulley design. Parallel self-cleaning magnets are mounted in line with the material flow, while transverse self-cleaning magnets remove the ferrous materials over the side of the conveyor.
ELECTRO FLUX Over Band Magnetic Seperator is available in permanent Magnet and Electro Magnet.
Over Band Magnetic Seperator consist of a stationary tri-polar design magnet unit, with coils wound in aluminum wire or foil (copper available as an option) dependent on size, and insulated to Class ‘H’ (or above) temperature specification to receive DC power supply. Magnets can be air or oil cooled, whichever is more suitable for the application. Oil cooled magnets are fitted with expansion tanks to ensure the coil is always immersed in oil.
Cross Belt & Inline Over Belt Separators
Cross belt Suspended Separator magnets provide a true self cleaning industrial magnetic separator systems solution, for continuous metal recovery from your conveyed materials. Ferrous metals are magnetically pulled out of your non-ferrous conveyed materials; ferrous materials collect on the self cleaning magnetic separator belt and are conveyed and discharged to your hopper.
ELECTRO FLUX Over Band Magnetic Seperator type uses a two-pulley design. self-cleaning magnets are mounted in line with the material flow, while cross belt self-cleaning magnets remove the ferrous materials over the side of the conveyor.
Self Cleaning Components
Shaft mounted speed reducer
PMDC motor
Heavy cleated rubber belt
Self-aligning sealed bearings
Four point suspension
Rugged structural steel frame
