Introduction: Replace BObi Pet's Screen
Replacing bObi Pet's screen is a very simple repair. Using a Phillips head screwdriver, you can open bObi up and remove the old screen. Follow these instructions or the video guide to easily complete this replacement.
Step 1: Turn BObi Pet Off
Before we get started, turn bObi Pet OFF and flip her over onto a flat surface.
Next, remove bObi Pet's dustbin. Grip the small tab on the back of the bin, and pull to remove.
Step 2: Remove the Front Wheel
Grip the front wheel and pull straight up, using the screwdriver for leverage.
The wheel will pop out and you will see two screws beneath it.
There is a larger screw set deeper in the wheel compartment. Use the screwdriver to remove it.
Remember to keep all screws and parts removed from bObi Pet safely aside during the repair. They may be needed for re-assembly.
Step 3: Remove the Dustbin Holders
Remove the screws on both sides of bObi Pet’s dustbin. Then, remove the corner pieces that were held down by the screws.
Grip the brush compartment and pull down to reveal two screws on a red fastener.
Remove them with the screwdriver.
Step 4: Remove the Main Brush Compartment
Pull the brush compartment up until the fastener is freed from bObi Pet. Then, detach the brush compartment's circuit plug and set it aside.
Remove the 4 screws located beneath the brush compartment.
Step 5: Remove the Cover Screws
Remove the 2 screws on the dustbin’s red fastener.
Remove the fastener and set it aside for reassembly.
The cover is no longer secured, so carefully flip bObi Pet onto her wheels.
Step 6: Disconnect the Cover
Lift the cover to reveal the main board underneath.
Remove the two circuit plugs connecting the lid to the mainboard. (Highlighted Blue)
bObi Pet's cover is entirely separated, and you may now access any of her internal parts for replacement.
Step 7: Remove the Screen
Remove the four screws holding bObi Pet's screen.
Then, lift it straight up and out to make space for the replacement.
Step 8: Install the New Screen
Lay the new screen in the open space on bObi Pet's lid.
Align the screw holes on the screen with the screw posts in the lid and push down until it lies flat.
Install all four screws, and you may start closing bObi Pet.
Step 9: Connect the Cover
Attach the two circuit plugs from bObi Pet's cover back onto her main board.
The yellow-wired plug connects to the right side of the mainboard. (Highlighted Yellow)
The white-wired plug on bObi Pet’s lid connects to the center of the mainboard. (Highlighted White)
Step 10: Align the Cover's Edges
Lay down bObi Pet's cover and line up the edges precisely.
While holding bObi Pet's top and bottom together, carefully flip her over onto a flat surface.
Step 11: Replace the Front Wheel
Reinstall the front wheel’s screw.
Then, place the front wheel on top and firmly push down to secure it.
Step 12: Secure BObi Pet's Cover
Replace the dustbin’s red fastener and install its two screws.
Install the four screws in the space beneath the brush compartment.
Step 13: Replace the Main Brushes
Plug in the brush compartment.
Then, replace its red brush compartment fastener on the screw posts inside bObi Pet and install the two screws.
Step 14: Replace the Dustbin's Holders
Position the brush compartment back in its original place on bObi Pet.
Insert the corner pieces on both sides of the dustbin, with the arms of the brush attachment linked.
Step 15: Replace the Dustbin
Ensure the rubber strip near bObi Pet's dustbin is not stuck underneath the brush compartment. Then, reinstall the two screws in each of the corner pieces.
Make sure the bin can slide in easily before using bObi Pet again and your repair is complete. Congratulations and happy cleaning!
