Introduction: Sunray Sr4 A8P Sim Card Triple Tuner DVB-S2/T2/C + WiFi TV Receiver
Product Description:
source from:
400 MHz MIPS ProcessorEnigma 2, Linux Operating Systemcolored OLED - DisplayMPEG-2 / H.264 Hardware decodingTuner: DVB-S,DVB-C, DVB-TTuner Module, Plug&Play2 x Smartcard-Reader (Dreamcrypt CA)Mini USB for Service and software update10/100Mbit Ethernet Interface1 x Scart (RGB, FBAS or S-Video)HDMI3 x USB 2.0 (e.g keyboard)analog modemS/PDIF Interface for digital bit stream out (AC-3)64 MByte Flash, 256 MByte RAMSATA- for internal HDD 2,5��unlimited channel lists for TV/Radiochannel-change time < 1 secondautomatic service scandirectly bouquet-listsEPG (electronic program guide)multiple LNB-Switching control (supports DiSEqC)OSD in many languages and skin-supportVideotext Decoderextern 12V power supplyTechnical Data:DBS-Tuner mit DVB-S2:Frequency Range 950 .... 2150 MHzDemodulation DVB-S (QPSK); DVB-S2 (8PSK,QPSK)Symbol rate DVB-S: 2 ... 45 Mbaud/s, SCPC/ MCPCDVB-S2: 10 �C 31 Mbaud/s (8PSK) , 10 �C30 Mbaud/s (QPSK)Video decoder:Video Compression MPEG-2 and MPEG-1 compatible, H.264Video Formats 4:3 / 16:9Letterbox for 4:3 TV-DeviceAudio decoder:Audiokompression MPEG-1 & MPEG-2 Layer I and II, MP3Audio Mode Dual (main/sub), StereoFrequency: 32 kHz, 44.1 kHz, 48 kHz, 16 kHz, 22.05 kHz, 24 kHzOutput analog:Output Level L/R 0,5 Vss on 600 OhmTHD > 60 dB (1 kHz)Crosstalk < -65 dBOutput digital:Output Level 0,5 Vss on 75 OhmSampled Data Filtering 32 kHz, 44.1 kHz, 48 kHzS/PDIF-Output optical, ToslinkAusgang Video:Ausgangspegel FBAS 1 Vss +/- 0.3 dB an 75 OhmVideo parameter:Input Level FBAS 1 Vss +/- 0.3 dB on 75 OhmTeletext filter in conformity with ETS 300 472 StandardTV-Scart:Output: FBAS, RGB, S-VideoMini USB service connector:Function: Update of FirmwareEthernet:10/100 MBit compatible interfaceFunction: Update of FirmwareAnaloge modem:analoge modem for Internet connectionSATA Interface:for internal 2,5" HDDUSB:3 x USB 2.0LNB power and polarisation per tuner:LNB Current 500mA max.; short-circuit-protectedLNB Voltage vertical < 14V no load, > 11,5V at 400mALNB Voltage horizontal < 20V no load, > 17,3V at 400mACount of active satellite position:DiSEqC 1.0/1.1/1.2 and USALS (Rotor Control)Power consumption:< 15W at 12VExternal PSUInput:110-240V AC / 50-60Hz / 0,6A
