Introduction: Sunray Sr4 Sim 210 Card Triple Tuner DVB-S2/T2/C + WiFi TV Receiver
Sunray sr4with sim 2.10 card triple tuner DVB-S2/T2/C + WiFi Adapter Sunray 4 hd se satellite tv receiver
source from www.sunraysat.com
Specifications:
Product Description: 400 MHz MIPS Processor Enigma 2, Linux Operating System colored OLED - Display MPEG-2 / H.264 Hardware decoding Tuner: DVB-S,DVB-C, DVB-T Tuner Module, Plug&Play 2 x Smartcard-Reader (Dreamcrypt CA) Mini USB for Service and software update 10/100Mbit Ethernet Interface 1 x Scart (RGB, FBAS or S-Video) HDMI 3 x USB 2.0 (e.g keyboard) analog modem S/PDIF Interface for digital bit stream out (AC-3) 64 MByte Flash, 256 MByte RAM SATA - for internal HDD 2,5�� unlimited channel lists for TV/Radio channel-change time < 1 second automatic service scan directly bouquet-lists EPG (electronic program guide) multiple LNB-Switching control (supports DiSEqC) OSD in many languages and skin-support Videotext Decoder extern 12V power supply Technical Data: DBS-Tuner mit DVB-S2: Frequency Range 950 .... 2150 MHz Demodulation DVB-S (QPSK); DVB-S2 (8PSK,QPSK) Symbol rate DVB-S: 2 ... 45 Mbaud/s, SCPC/ MCPC DVB-S2: 10 �C 31 Mbaud/s (8PSK) , 10 �C30 Mbaud/s (QPSK)
Video decoder:
Video Compression MPEG-2 and MPEG-1 compatible, H.264 Video Formats 4:3 / 16:9 Letterbox for 4:3 TV-Device Audio decoder: Audiokompression MPEG-1 & MPEG-2 Layer I and II, MP3 Audio Mode Dual (main/sub), Stereo Frequency: 32 kHz, 44.1 kHz, 48 kHz, 16 kHz, 22.05 kHz, 24 kHz
Output analog:
Output Level L/R 0,5 Vss on 600 Ohm THD > 60 dB (1 kHz) Crosstalk < -65 dB
Output digital: Output Level 0,5 Vss on 75 Ohm Sampled Data Filtering 32 kHz, 44.1 kHz, 48 kHz S/PDIF-Output optical, Toslink
Ausgang Video:
Ausgangspegel FBAS 1 Vss +/- 0.3 dB an 75 Ohm
Video parameter:
Input Level FBAS 1 Vss +/- 0.3 dB on 75 Ohm Teletext filter in conformity with ETS 300 472 Standard
TV-Scart:
Output: FBAS, RGB, S-Video Mini USB service connector: Function: Update of Firmware
Ethernet:
10/100 MBit compatible interface Function: Update of Firmware Analoge modem: analoge modem for Internet connection SATA Interface: for internal 2,5" HDD USB:
3 x USB 2.0 LNB power and polarisation per tuner: LNB Current 500mA max.; short-circuit-protected LNB Voltage vertical < 14V no load, > 11,5V at 400mA LNB Voltage horizontal < 20V no load, > 17,3V at 400mA Count of active satellite position:
DiSEqC 1.0/1.1/1.2 and USALS (Rotor Control)
Power consumption:
< 15W at 12V External PSU Input:
110-240V AC / 50-60Hz / 0,6A
more information: www.sunraysat.com
