Can someone explain what all these connections on this transformer are for?
Anyways, I want to see if I can possibly use this transformer in a DC circuit to increase the voltage, but it would help if someone could explain which wires are connected to the primary and secondary windings! Also it would be nice if someone told me if it's even possible to increase the voltage in a dc circuit. For example, is there a way I can connect this transformer to a battery so that it converts 1.5v to something higher?
If you look at the picture, I think the 6 connections poking out just under the yellow part are all connected to the two wires coming out at the top beside my index finger. Then there are two leads and the bottom. Anybody know what they do? I connected one end of a 1.5v battery to one of the leads at the bottom and when I rub the other end of the battery on the other lead it produces small sparks.
Visit Our Store »
Go Pro Today »
In order to use the transformer as park of a step-up DC-DC converter, you'll need a whole lot more parts than just this transformer! Basically, you need to convert that 1.5V to AC, send it through a transformer, then convert it back to DC. A google search should yield a schematic or two.
Also, stop hooking up that poor battery directly to the transformer! You're shorting it out. Batteries don't like that.
And for the output you can use multimeter after making connection , which give different output voltage ranging from 1.5-12V....And remember not to short them in any possible ways...Their must be one which is common called 'transformer common' , we generally use the first one as the common...For testing with multimeter, put black probe in transformer common and put the red probe in the remaining terminals, one by one.... And see the reading ...
In this way you would be able to use different voltage for different purpose....
And don't forget to conver it in DC using IN4007 Diode.....
http://www.rowan.sensation.net.au/electronics/stepup.html
