Does Plaster of Paris shrink?
Does Plaster of Paris shrink as it dries? I would like to make a mask out of it but I don't wan't it to shrink and crack.
Gratias agimus tibi,
josh1324
Jul 25, 2011. 11:04 AMBurf says:
No, it doesn't shrink. That's why it is used for things like paster cast impressions by police departments, and molds for casting gold and silver jewelry, etc.
Jul 25, 2011. 11:47 AMsteveastrouk says:
Well, it does shrink a bit - try doing thick sections.
Steve
Jul 25, 2011. 2:00 PMBurf says:
Its been a long time since I studied this, but as I recall, basic plaster of paris, without additives, actually expands slightly as it is curing. In the neighborhood of 0.3% to 0.5 %, nominal, if memory is correct. I don't recall the figures, but thermal expansion and contraction is also relatively small.
Jul 25, 2011. 2:33 PMsteveastrouk says:
True, buts it shrinks very slightly in storage, so that dental impressions can be problematic
Jul 25, 2011. 2:18 PMrickharris says:
It will do what you want - DO NOT totally encapsulate any body past in Plaster of Paris.
you may find making a mould with alginate works better than a direct plaster cast,
Jul 25, 2011. 12:30 PMrojo.balloon says:
Plaster will not shrink as it dries, therefore, it can be used to create a court-admissible cast as well as a reference which can be used in an investigation.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
