3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Does anyone know how to hook up a motor to a rectifier and then hook up the rectifier to a capacitator and LED?
Hi Does anyone know how to hook up a motor to a rectifier to convert AC to DC. Then the current needs to be passed to a capacitator, and finally discharged to an LED. I am doing this for my science fair. Thank you!
Feb 27, 2009. 7:46 PMfd18 says:
Are you sure your motor is producing an AC voltage. If it's not, there are a couple things you can do. First, you could just connect the DC power source(motor) directly to your LED. Or depending on what you really want to do you can have an external AC power source, rectify it, then put your motor and LED in parellel to make them run at the same time.
Feb 1, 2009. 1:13 PMchief tyrol says:
This is a circuit diagram. Any capacitor above 100uf and rated for twice the voltage that this will produce should work
Jan 31, 2009. 6:22 PMjeff-o says:
The rectifier might be marked with four symbols: ~ and ~ and + and -. The two ~ symbols connect to the outputs of the AC motor. You can guess the rest: + is positive, - is negative.
Jan 31, 2009. 4:55 PMSparkington says:
Well this link will help, where it says load connect your led. The ac source will be your motor. Hope this help. Circuit Diagram
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
