I need help! Im trying to get rid of two pictures, due to legal reasons, when i do this, it says the pictures are in use! What do I do, help me out ASAP?
I'm assuming you're using them on an instructable?
If so, you need to "edit" the instructable (or wherever they are "in use") and remove them from there first and then you can delete them from your library.
PDF Downloads As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
In the corner of the thumbnail will be a small X.
Click it.
If you ignore the warnings, and keep on clicking, images will go away, both from the library, and everywhere you have used them around the site.
If this wasn't what you meant, then let me know.
Not working. Clicked and clicked not working. I NEED THIS GONE!
