Using a Benchtop PSU to heat wires?
11
answers
Answer it!
Seconded seandogues idea of a suitable slo-blow fuse in SERIES with the hot wire. Use ohms law to calculate the required fuse. Measure the ohm resistance of a length of your hot-wire, and use ohm's law to calculate the needed amperage at a given (known, probably 12) voltage.
example: measure your wire is 25 ohms.
V=IR
12 = I * 25
I = 12/25
I = 0.48amps. a 12v .5amp slow blow (maybe .6 or .7 amp) fuse would probably be better, blow less often.
Your heat-wire (probably nichrome?) itself will regulate the current output by its relatively stable resistance as the temperature changes.
a filtered PWM circuit can be made to change the average current to attain different temperatures. There are lots of schematics and readings on this website.
Adjustable current regulation circuits can be made very easily using little more than a cheap LM317and a few extra components. Circuits are available via the LM317 datasheet or literally hundred of websites via a quick google search on the term "current regulator" or "current regulator lm317"
I say adjustable to clue you to the idea that adjusting your output to suit a particular hotwire might be a good thing, yes?
