What should I expect to see from my Leydens jar?
5
answers
Answer it!
Alternately, you can hold the top terminal of the jar close to a CRT or TV screen. Static electricity will collect in the jar, albeit somewhat slowly.
A problem you may be having is grounding. Do your Leyden jars have good ground contact? The metal lining on the outside of the jar must come into contact with something grounded--a metal stove top, a steel sink, etc. Without a good ground connection you can't accumulate much charge.
Try this site for more hints: http://www.alaska.net/~natnkell/electrophorus.htm
Let us know if these suggestions help!
Paul
Use a higher-voltage supply to charge it - if you can't get an actual electrostatic generator, use the screen of a cathode ray tube (non-LCD TV or computer monitor) as you switch it on and off.
