loading
help with arduino code?
I am making a project for my 6 DOF arm and I want to control the arm with a remote. I found a code for just that, but with only one servo and I am hoping somebody can help me out with changing the code to control 6 servos. please help me!!!
the code is shown below.
#include <IRLib.h>
#include <Servo.h>
// You will have to set these values depending on the protocol
// and remote codes that you are using. These are from my Sony DVD/VCR
#define MY_PROTOCOL NEC
#define RIGHT_ARROW   0xffc23d //Move several clockwise
#define LEFT_ARROW    0xff22dd //Move servo counterclockwise
#define OK_BUTTON     0xff02fd //Center the servo
#define UP_ARROW      0xff629d //Increased number of degrees servo moves
#define DOWN_ARROW    0xffa857 //Decrease number of degrees servo moves
#define BUTTON_0      0xff4ab5  //Pushing buttons 0-9 moves to fix positions
#define BUTTON_1      0xff6897  // each 20 degrees greater
#define BUTTON_2      0xff9867
#define BUTTON_3      0xffb04f
#define BUTTON_4      0xff30cf
#define BUTTON_5      0xff18e7
#define BUTTON_6      0xff7a85
#define BUTTON_7      0xff10ef
#define BUTTON_8      0xff38c7
#define BUTTON_9      0xff5aa5
IRrecv My_Receiver(11);//Receive on pin 11
IRdecode My_Decoder;
Servo My_Servo;  // create servo object to control a servo
int pos;         // variable to store the servo position
int Speed;       // Number of degrees to move each time a left/right button is pressed
void setup()
  My_Servo.attach(9);  // attaches the servo on pin 9 to the servo object
  pos = 90;            // start at midpoint 90 degrees
  Speed = 3;           //servo moves 3 degrees each time left/right is pushed
  My_Servo.write(pos); // Set initial position
  My_Receiver.enableIRIn(); // Start the receiver
void loop()
    if (My_Receiver.GetResults(&My_Decoder)) {
       My_Decoder.decode();
       if(My_Decoder.decode_type==MY_PROTOCOL) {
          switch(My_Decoder.value) {
            case LEFT_ARROW:    pos=min(180,pos+Speed); break;
            case RIGHT_ARROW:   pos=max(0,pos-Speed); break;
            case OK_BUTTON: pos=90; break;
            case UP_ARROW:      Speed=min(10, Speed+1); break;
            case DOWN_ARROW:    Speed=max(1, Speed-1); break;
            case BUTTON_0:      pos=0*20; break;
            case BUTTON_1:      pos=1*20; break;
            case BUTTON_2:      pos=2*20; break;
            case BUTTON_3:      pos=3*20; break;
            case BUTTON_4:      pos=4*20; break;
            case BUTTON_5:      pos=5*20; break;
            case BUTTON_6:      pos=6*20; break;
            case BUTTON_7:      pos=7*20; break;
            case BUTTON_8:      pos=8*20; break;
            case BUTTON_9:      pos=9*20; break;
        My_Servo.write(pos); // tell servo to go to position in variable 'pos'
     My_Receiver.resume();
Create more servo objects.
Where you have
Do
Servo My_other_servo;
Servo My_other_other_servo;
void setup()
My_other_servo.attach(pin number whatever)
My_other_other_servo.attach(pin number whatever again)
Don't forget, you will need a lot of power to run 6 servos successfully.
ibenkos (author)  steveastrouk2 years ago
I understand how to do it in the void setup but the void loop is complicated. can you help me there?
ibenkos (author) 2 years ago
I finally got it working, I just tested some different stuff and found out what I had to do, and the code works!
#include <IRLib.h>
#include <Servo.h>
Servo My_Servo1; // create servo object to control a servo
int pos1; // variable to store the servo position
int Speed1; // Number of degrees to move each time a left/right button is pressed
Servo My_Servo2; // create servo object to control a servo
int pos2; // variable to store the servo position
int Speed2; // Number of degrees to move each time a left/right button is pressedServo My_Servo; // create servo object to control a servo
Servo My_Servo3; // create servo object to control a servo
int pos3; // variable to store the servo position
int Speed3; // Number of degrees to move each time a left/right button is pressedServo My_Servo; // create servo object to control a servo
Servo My_Servo4; // create servo object to control a servo
int pos4; // variable to store the servo position
int Speed4; // Number of degrees to move each time a left/right button is pressedServo My_Servo; // create servo object to control a servo
Servo My_Servo5; // create servo object to control a servo
int pos5; // variable to store the servo position
int Speed5; // Number of degrees to move each time a left/right button is pressedServo My_Servo; // create servo object to control a servo
Servo My_Servo6; // create servo object to control a servo
int pos6; // variable to store the servo position
int Speed6; // Number of degrees to move each time a left/right button is pressed
void setup()
My_Servo1.attach(3); // attaches the servo on pin 9 to the servo object
pos1 = 90; // start at midpoint 90 degrees
Speed1 = 10; //servo moves 3 degrees each time left/right is pushed
My_Servo1.write(pos1); // Set initial position
My_Servo2.attach(4); // attaches the servo on pin 9 to the servo object
pos2 = 90; // start at midpoint 90 degrees
Speed2 = 10; //servo moves 3 degrees each time left/right is pushed
My_Servo2.write(pos2); // Set initial position
My_Servo3.attach(5); // attaches the servo on pin 9 to the servo object
pos3 = 90; // start at midpoint 90 degrees
Speed3 = 5; //servo moves 3 degrees each time left/right is pushed
My_Servo3.write(pos3); // Set initial position
My_Servo4.attach(6); // attaches the servo on pin 9 to the servo object
pos4 = 90; // start at midpoint 90 degrees
Speed4 = 3; //servo moves 3 degrees each time left/right is pushed
My_Servo4.write(pos4); // Set initial position
My_Servo5.attach(9); // attaches the servo on pin 9 to the servo object
pos5 = 90; // start at midpoint 90 degrees
Speed5 = 3; //servo moves 3 degrees each time left/right is pushed
My_Servo5.write(pos5); // Set initial position
My_Servo6.attach(10); // attaches the servo on pin 9 to the servo object
pos6 = 90; // start at midpoint 90 degrees
Speed6 = 3; //servo moves 3 degrees each time left/right is pushed
My_Servo6.write(pos6); // Set initial position
void loop()
case LEFT_ARROW: pos1=min(180,pos1+Speed1); break;
case RIGHT_ARROW: pos1=max(0,pos1-Speed1); break;
case BUTTON_0: pos2=min(180,pos2+Speed2); break;
case BUTTON_1: pos2=max(0,pos2-Speed2); break;
case BUTTON_2: pos3=min(180,pos3+Speed3); break;
case BUTTON_3: pos3=max(0,pos3-Speed3); break;
case BUTTON_4: pos4=min(180,pos4+Speed4); break;
case BUTTON_5: pos4=max(0,pos4-Speed4); break;
case BUTTON_6: pos5=min(180,pos5+Speed5); break;
case BUTTON_7: pos5=max(0,pos5-Speed5); break;
case BUTTON_8: pos6=min(180,pos6+Speed6); break;
case BUTTON_9: pos6=max(0,pos6-Speed6); break;
My_Servo1.write(pos1); // tell servo to go to position in variable 'pos'
My_Servo2.write(pos2); // tell servo to go to position in variable 'pos'
My_Servo3.write(pos3); // tell servo to go to position in variable 'pos'
My_Servo4.write(pos4); // tell servo to go to position in variable 'pos'
My_Servo5.write(pos5); // tell servo to go to position in variable 'pos'
My_Servo6.write(pos6); // tell servo to go to position in variable 'pos'
Nice job. Well done !!
Kiteman2 years ago
Try asking this in the "Tech" forum, it gets more traffic.
ibenkos (author)  Kiteman2 years ago
Isnt that what I did? I added it in technology as Arduino
Kiteman ibenkos2 years ago
This is the Q&A section, which gets less traffic than the main forums.
Tech is here:
https://www.instructables.com/community?categoryGro...
(Hit the New Topic button near the top-right of the page.)
More traffic= more noise.
