loading
10 bit to 7 segments
Hi everyone!!
I'm posting because i need help! I want to make a 10 bit to 7 segments schematic/circuit.
I need to just convert 10 bit binary to decimal.. In my idea i have 10 switches and every one of them represents a number in decimal.
for example when i put ON my first switch from the right i want that in the 7 segments appears the number "1" and for example when i switch ON the last switch from the left it appears "512" and if all of them are ON appears 1023.
So i have 10 ON/OFF switch and 4 (7 segment) display.
I have a PIC programmer, so if anyone can help by hardware or software it would be great.
Thank you very much!!!
Grieverjoao (author) 4 years ago
Thank you very much for the reply but i don´t understand most of it!
I'm not very friendly with programming if anyone can help me i would appreciate it!
I have a Pic programmer that supports PICs, 8p, 14p, 18p and 24p my kit is a PIC PROGRAMMER & EXPERIMENT BOARD from VELLEMAN, its the kit K8048.
I never programmed with this kit and I only know a little bit c++.
I hope anyone can teach me on the programming.
You could start out with programming 8 bit binary to decimal first. It seems that what the kit is designed to do.
Grieverjoao (author)  caitlinsdad4 years ago
The problem is that i don't know how to do that. I never worked with PICs.. sorry
Do you know what binary numbers are? Have you read the examples they provide with your kit? Is it hooked up to the computer?
I know what binary numbers are. The examples i didn't read them because i don't have them. This was a gift from a friend and i only have the board. Nothing more.
I have searched found a way to do it and i understand the concept but i don't know how to make it... The solution is the algorithm double dabble. http://www.microchip.com/forums/tm.aspx?high=&m=439637&mpage=1#439669
But i don´t know how to put this in the Pic and after that i don't know how to connect the 5 7segments to the Pic
http://www.vellemanusa.com/support/downloads/?code=K8048
 Starting out on a PIC might be more obscure since it gets closer to the more cryptic machine level programming.  I am sure there are tutorials out there for using a PIC.  I think you have to get one digit to display before you can move on to a standard 8-bit display.
http://www.microchip.com/forums/m210149-print.aspx
P
robably more techniques out there but essentially gather up your switch inputs to create a string to be parsed and calculate the decimal number.  Good luck.
