Introduction: How to Get a Home-run in Baseball
This will show u how to geta good hit or a HOME-RUN in baseball
Step 1: Loading Up
when the pitcher is lifting his or her leg u should lean back a little to get power.
Step 2: The Stride
now that our loaded u can stride.a stride is when the ball is in the air you lift your front leg a inch or two off the ground and now u have two times the power
Step 3: Pivet
when u think its the right time u have to pivet a pivet is when u twist your legs in a circle but not moving your chest or higher.
Step 4: The Swing
i saved the best for last...the swing.i cant help u with the swing its YOUR swing so u have to make shur u have lots of power and that your timing is right.
Step 5:
hope this helped u and go get a HOME-RUN!!!!!!!!
