Introduction: How to Reuse Plastic Bottles
Hello, instructables friends, today I want to share how to reuse containers or plastic bottles of some liquids, such as automotive oil in a small suitcase.
Step 1:
Hello, instructables friends, today I want to share how to reuse containers or plastic bottles of some liquids, such as automotive oil in a small suitcase. You can also use any other type of container Similarly, this oil must have been with new oil, oil used, never, never, or if you have trouble cleaning, use one with another product, laundry soap, remover insects or any bottle similarly shaped
Step 2:
for this project you will need, the following:
a plastic bottle, one gallon.
a cutter
. 1 1/2 maskingtape wide
. a multiple holemaker.
embroidery floss or nylon.
Velcro scissors.
2 zippers.
a sliding band of an old bag.
pop Riveter
2 pop rivets.
a neddle
before begins , deciding where the zippers go.
, pointing to his position with the maskintape.
Step 3:
you will cut in the maskingtape line of whit knife at the beginning and then with the scissors.
Step 4:
pierce outside the cut in line and position the zipper, begin to sew the bottom up, so it's better and easier. you have to choose a big needle. (the nylon thread is better)
Step 5:
shown here the two sewn zippers and Velcro for a good enclosure and fit.
Step 6:
here shows a clear aimagen as the zippers are sewn Velcro and an image by installing the old band back pack with a rivet, notice how it is to install a plastic washer inside the aluminum rivet.
Step 7:
Here shows a clear picture of how the rivet is installed on the other side, and another image of the small suitcase to use is very comfortable and has an easy acseso inside, thank you very much for your attention, I hope this instructable serve you, create other ideas, regards, sincerely: Charly arrieta
