How to Make a Papier Mache Side Table
Introduction: How to Make a Papier Mache Side Table
Imagine a land where side tables were outlawed. There are few who will stand up and resist such a dark regime that oppresses innocent floor space... it is up to the few, to oppose this great wave of darkness and clutter! Come join the resistance, begin the fight, recycle, reuse and make a papier mache side table.
Step 1: Materials & Design
You will need...
A design: This design just happened as I went along, the dimensions came from marks on a length of wood I used as a ruler (that's why they have no rhyme or reason, sorry). As long as you are consistent with the basic dimensions, your table should look great. I have included my dimensions just in case you want to make an exact replica.
For the side table structure:
Cardboard (for the basic structure of the table)
Duct tape, scissors and marker pen
Lots of scrap paper (for the papier mache)
Cornstarch (or cornflour), water, measures and a bowl
For painting and distressing:
A few colours of paint (black, grey green and metallic gold)
A wax candle (to help with distressing)
A sharp edged tool (like a knife to help remove paint from edges)
A little paint remover (to help create a crinkly distressed look)
A brush and cloth (to apply paint)
Step 2: Mark & Cut Out Pieces
Mark out the sides and shelf/back piece with your marker pen. Using your scissors, cut out the side pieces and shelf/back piece and score along any lines that will need to be folded.
Step 3: Tape Shelf/Back to Sides
Using duct tape, attach the shelf/back piece to the sides. First tape the tabs in place, then cover the remaining joints with tape.
Step 4: Construct the Table Top
Using additional pieces of card, construct the side table's top. I initially used two layers of card taped together, but then decided to add a third for strength. Attach to the base by taping around the edges (the back of the top should be flush with the base's).
Step 5: Cover All Edges With Duct Tape
To strengthen the edges of the cardboard, hem or cover them with duct tape.
Step 6: Construct Facade & Attach
Mark and cut out the facade from a piece of card. The facade helps with the structure's stability and also makes it look more solid from the front. Attach to the front using duct tape.
Step 7: Prepare Papier Mache Mixture
Mix between 2-4 tablespoons of cornstarch (or cornflour) with as much water to make a thick mixture. Add 1 litre of boiling water and mix well. If you add more cornstarch, you will get a harder (and slightly more textured) finish.
Step 8: Cover Table With Papier Mache
Tear lots of pieces of scrap paper into thin strips. Immerse strip and wipe off excess liquid with your fingers. Strip by strip, slowly wrap the entire table with your papier mache mixture. Perhaps, to prevent the cardboard from becoming too damp, you could wrap a panel at a time, allowing to dry before continuing.
Step 9: Paint & Distress
There are many ways to gain a distressed paint look. Some people use many different coats of water based paint and with sanding edges and corners you can achieve a weathered and antique looking finish.
For this project I decided to go for a metallic distressed look. First paint the table with a dark colour (I used an oil based black). Next, you can rub a wax candle along the edges to help the next layer of paint to be removed without removing the first. When applying the second layer (I used an oil based grey/green), I added a little paint remover to the mixture to encourage a crackling texture in places. Don't worry about drips and an uneven finish, that's what we want. After the second layer is dry you can remove parts some of the paint (mostly along edges/corners) with a sharp edged tool. Even if your second layer is still a little sticky, you can still distress the finish by being a little rough with it.
Step 10: Finishing Touch of Gold
Finally, take a cloth with metallic gold paint on it and rub over the entire surface. You will notice that the edges, corners and imperfections will naturally gain more gold than the smoother surfaces. This gives the table a fantastic metallic distressed appearance.
Step 11: Side Tables for All
Papier mache side tables are light, stable, versatile and can really help decorate a home. Join the fight against clutter... reclaim your floor space with this simple paper side table.
    • Paper Contest 2018
      Paper Contest 2018
    • Science of Cooking
      Science of Cooking
    • Pro Tips Challenge
      Pro Tips Challenge
    nice i'll make it too... did you guys(that made it) notice any signs of mold because of the cornflour after a while or is it safe??
    Absolutely no mould... as long as it's dry and especially if you paint it... then it's not likely to show any sign of mould...
    SO this is three years later, still no mould? That's great!! I know in Oklahoma anything paper in my in-law's house could get mouldy, because they did not have central air conditioner and it gets very hot and humid. I'm wondering if in climates where mould is an issue, maybe some diatomaceous earth mixed in with the cornstarch and water mixture might be enough to help head it off at the pass, especially if some white vinegar used as part of the water/liquids to thin it down?? Just a thought. I'm actually thinking of borrowing elements of this awesome design for a shelf project I've been wanting to remodel. It's a cheap melamine-topped particle board shelf kit that got heat damaged by the in-laws, so that the pretty white ended up with horrible brown yellow spots in random places. I want to repurpose it as a shelf for my coffee "stuff" (I had a K-cup and it recently died, but I still have stuff like those Vietnamese style stainless steel coffee/espresso strainers, pretty coffee boxes/tins, etc etc so just a place to put all the clutter, especially as I'm likely to get a replacement coffeepot later.). I loved the ideas about the painted distressed look, and the gold paint on it. So I'm still not sure how I will do it all, but I really appreciate your time in posting this instructable!! I hope it is still working well for you all this time later!
    Oh! speaking of the gold paint... would the gold foil type stuff work too, do you think, with maybe some sort of spoon or boning tool to mash into the surface in random edges? I bought some a long time ago for some other project (I can't even remember what it was I thought about doing with it!! It's been that long ago....). Duuuh, I guess I can go search for a "gold foil" instructable!! haha
    Hey msdrpepper! Thanks for your encouraging comments on the side table. Yes, it's still going strong, with no sign of mould, I've even added extra papier mache furniture (book shelf & coffee table) to extend the craziness. I wonder if a dehumidifier would help if anyone finds themselves in a really humid environment ;)
    Thanks again and all the best!
    Would there be any inconvienience in keeping it the way it is in step 9, pic 1?
    If you are happy at that point then great, I just wanted a different distressed look :)
    Very unusual and creative. I like the idea. Thanks for sharing!
    Thank you for your encouragement, belisa!
    Thanks for reading :)
    Well done. Thanks for including so many pictures! I thought the cleaner lines of the cardboard looked better than the uneven look of the paper mache, but I understand if the paper mache is required for additional strength. However, when I first looked at the pictures, I thought your side table was covered in foil! It wasn't until I read the step about painting it that I realized it was just metallic paint.
