Remove these ads by
Signing UpStep 1What you need
-A 9V battery clip with a flat cover made of plastic
-A 9V battery
-LED (any color although it should be clear in order to see it better)
-330 ohm resistor (orange-orange-brown-gold or silver)
-Infrared Phototransistor
-perf board (see 2nd picture)
-double sided mounting tape
-wire
-needlenose pliers
-wire snipper
-dremel or hack saw to cut perf board
-clear epoxy-like glue
-Soldering equipement:
-soldering iron
-solder with flux core
A shematic is given in step 12, picture #4.
I hope it answeres most of your questions, if not, let me know.
Thanks
You could add a red LED, but that would use up too much circuit board space to make it fit on a 9V battery clip.
The detector though will register some IR light when used in sunlight, as it containes light from the infrared spectrum.
On the other hand, you could just remove the detector from the battery to be sure that no eletricity is wasted.
If you need higher sensitivity, there are also photodarlingtons, which, if you aren't familiar with darlington transistor configurations, have 10-100x the gain.
if so, one could replace the LED with another IR LED, (and potentially an extension lead) and create a low-cost IR repeater, for using remotes across corners, in other rooms, etc.
(I tend to find practical uses for things like this)
http://www.instructables.com/id/IR-Detector/
I know why you used a 330 ohm resistor. Not everyone will. Could you add a simple calculation on why a 330 ohm resistor with the 9v battery? :-)
I * R = E
0,012amps * 330ohm = 3.96volts
which is safe enough for the clear LEDs
great idea and could be very useful when testing for IR from remotes and the like, but I personally always like to see a circuit diagram before building anything, even something this simple/easy......can you add a simple sketch of the connections.
I could probably work it out myself, but me being born lazy......
For anyone else who maybe wants to understand the operation better, they may agree with me.
Full marks though for simplicity and ease of use, many thanks.
Regards
Andy
PS If there is already one here and I did not see it, I am VERY unobservant, apologies/sorry!
Regards
Andy
First thing I did was hit "show all steps" and then skim for the schematic (and then fav your project).
You need an I.R, detector.
Try Maplins, or Radiospares.
Perhaps I'll try and Idea I have.
