The picture is self-explaining. The small disc contains the originals chords of the song, and great the wished ones.
Both discs are united by the center and turn one on the other.
I used a pair of washers to fill up the central hollow of discs, and another pair of greater washers to unite the set with an aluminum rivet. A screw can also be used, or what the talent suggests to you.
In the case of the photo (the first photo), a song in E will be transposed to A.
Consequently:
D --> G
C --> F
F --> A#
... and so
(Pardon my deplorable english. I speak spanish.)
Remove these ads by
Signing Up| « Previous Step | Download PDFView All Steps | Next Step » |
Ya que estamos, ¿me votaste para el woodworking contest? http://www.instructables.com/id/Relieve-en-madera-fcil-wood-relief-made-easy/
http://www.instructables.com/id/Torneando-un-trompo-lathing-a-top/
(Look, I explained not too much because what counts are the photos. It's simple: a large disk over which rotates a smaller concentric. It could be a great CD and one little, but as these are expensive, what I did was cut a big one. Link them at the center with you can: a screw, a clip, etc, but each CD can rotate relative to the other. Then draw 12 equal sectors, corresponding to the 12 semitones of the chromatic scale, put the name on both discs, and play. When the names match, there is no transposition. If you want to go for example from C to D #, turn a disk to match the one C to D # on the other, and find the other notes in the same way)
By the way, "voted you for me at the woodworking contest?
¿Ha considerado utilizar iGoogle para traducir frases?
http://www.google.com/ig
This CD wheel inspired me to make a paper one - I've seen others on the web, but I think this one turns out cleaner:
HumboldtMusic.com: Chord Wheel pdf
Laminate the pieces and stick them together with a tack (point bent sideways & taped). Far less durable perhaps, but maybe a touch less labor involved?
Keep up the good work!
Mike Craghead
humboldtmusic.com/mc
The CDs has better aspect, but it is necessary to get one of the littles CDs, else to cut one big, and also is the topic of the central hole that it is necessary to stuff with washers.
I also have a separate one for the circle of fifths and the blues scale. Just got inspired on a new way to do it (better, even!).
How did you cut the inner CD without cracking it?
http://www.chordwheel.com/
I ordered one of these and when I got it I did the old forehead slap thinking I could have made one.
