A Precise Table Saw from an Electric Hand Saw
This photo is from 1972.  It shows me using a table saw I made with an electric handsaw, also known as a circular saw.
Some will say, "Why bother?" since you can now buy an inexpensive table saw for the same amount of money.  True, but the adaptation shown here allows the user to remove the saw  from the table at any time and rip panels or frame houses, and then return the saw to its table precisely aligned and ready to do close fitting work.  You cannot enjoy that dual purpose usage with an inexpensive commercial table saw.
This Instructable differs from similar Instructables because it offers that precise mechanism for automatically and exactly aligning the saw each time it is returned to its table.  Details of this are in Step 16.
If you want yet another alternative for making your circular saw an accurate woodworking machine, see my earlier Instructable Get More from Your Circular Saw.
Step 1Making the miter gauge
This is a good time to decide on the miter gauge you will use with your saw, and make or buy it.  When I made this table saw conversion, I purchased a commercial miter gauge.  The steps that follow will show you how to make a good miter gauge yourself.
If you choose to make your own, begin with a straight steel bar.  The one shown is 1/4 x 3/4 inch and about a dozen inches long.  It is what I had at the time.  I would recommend a bar of 3/8 x 3/4 inch steel about 18 inches long, but 1/4 x 3/4 inch may be easier to find and works well, too.  Round the edges at the ends a little with a grinder so the miter gauge moves more freely in the slots.  The photos in this step and the next steps are from my previous Instructable titled Bench Saw Table for a Lathe.
79 comments
1-40 of 79next »
Dec 16, 2011. 6:54 PMshazni says:
please may i know how to do a opening with a miter cut in the middle of a board?
do you like do a plunge miter cut like a pocket cut?
i'm a new woodwork hobbyist and would like a bit of help please.
thanks
Nov 29, 2011. 9:38 PMOndra78 says:
Thanks for the project. I make a similar saw.
I add photo of machine.
Dec 3, 2010. 3:34 AMlottfamily says:
You and "your followers" spend a lot of time in these comments speaking lowly of Norm Abram (I really wanted to use stronger wording but I am trying to be polite). None of you have obviously spent much time at all checking out his total body of work. He truly is a master carpenter. When he began to do NYW the purpose of that particular show was to show and instruct building with power tools. If you spend some time reading some of his written work and watching early episodes of both NYW and TOH, you will see that his skill and knowledge is really top notch.
As far as an "expensive shop" vs an "inexpensive shop" I do finish carpentry and cabinet installation for a living and have seen without fail that the better carpenters get more jobs=make more money=set themselves up better. While the less skilled carpenters...well you get the idea. If I couldn't afford a table saw at today's prices for that particular tool then I am in the wrong business.
Dec 19, 2010. 5:38 AMnoesc says:
This is how you handle trolls and "My dad is better then your dad" comments.
It even takes care of comments with a good point, but is so far off topic it could be its own instructable.
Thank you!
(And I will keep your instructable close at hearth for future needs. It's awesome!)
Jan 4, 2010. 10:51 AMAngryRedhead says:
This is amazing and wonderful, and it's so much better to have multipurpose tools than tons of single purpose tools.  Very nice!
Jan 4, 2010. 11:44 AMAngryRedhead says:
I think you should write a letter to New Yankee Workshop about this.  ;-)
Sep 27, 2010. 3:01 PMglorybe says:
I spent a lot more time than I liked using a cut off saw on brass and aluminum. Frankly I hate composite blades. Our local rental shop lost a mechanic when a concrete saw blade exploded and sent a shard into his crotch. The bleeding could not be stopped in time to save his life. The poor guy just started the saw to make sure it was running right for the next customer and it was all over for him. After that any time I spent around any type of composite blade made me leery.
Unfortunately I had to do an awful lot of cutting of steel with a composite blade. And that saw was a high powered industrial unit so any error at all could trigger a really violent reaction.
Jan 7, 2010. 9:51 PMstatic says:
  Sometimes I think Norm could use lessons from Roy Underhill.
Jan 7, 2010. 9:53 AMiamchrismoran says:
 yeah, I thought yankee and thrifty went hand in hand. NYW isn't for the light walleted.... but the fancy minded. I fancy someday I'll pull some of those projects off.
THIS project however:
I'll need to read through it a few more times to see how it'll apply to my circular saw, but I'm so happy to see this posted. I have had this precise project want in mind for as long as I realized that I'd likely want to spend more on a table saw than I should. I have a bandsaw that I'm not positive I have set up right, since it doesn't seem give perfectly straight vertical cuts and repurposing the circ saw would be an interesting option.
Sep 27, 2010. 3:04 PMglorybe says:
I had a Porter Cable jig saw (industrial) and I could zip through 3/8 boiler plate on pieces 8 feet long. That jig saw had really serious power and saved me a ton of work. If one lacks a torch cutting system that little saw is a fabulous way to make long cuts in steel. In a couple of minutes I could run through an 8 ft. cut and chuck the piece in a mill to give the accurate, final cut.
Mar 8, 2010. 12:13 AMkulin62 says:
I have a Bosch GKS 190 Professional circular saw (1400W, 4.1 Kgs.) and was looking for ideas to convert it to a table saw. And I found this excellent i'ble. Thank you Phil.
My saw has the blade guard. Since you have mentioned in the Step 7 to keep the opening as small as possible to prevent scrap bits of woods going under, I assume that the slot in the saw table will not be wide enough to accommodate the guard to come up. is this correct?
My saw base does not have any holes, but surprisingly has four half-a-mm-deep stampings of 5/8 th inch dia. Probably they envisaged the conversion. But they have riveted and fused the base plate with the main body. So I have to figure out how to drill holes now.  I am contemplating using all the four holes for mounting along with the blocks with screws for alignment as in step 16. Any particular disadvantages of four mounts besides time taken to remove the saw?
While googling for the conversion ideas, I read somewhere about someone having a problem of the sawdust spewing up the table to the face. Phil, did you have any such problems? My saw has a slot for the sawdust to come out and attaching the dust extraction unit.
I am also contemplating having 2 slots (like the ones for mitre guage) one each near the front and back of the table running perpendicular to the mitre slots, have two more steel flats and attach a straight edge to them to act as a sliding rip fence. Any suggestions or comments, Phil?
Thanks again for the wonderful i'ble.
Regards.
Kulin
Sep 8, 2010. 8:02 PMBroom says:
i did not want to mention that in the body of the Instructable because several people would comment on nothing else and criticize me severely.
Bwahahaha! Isn't that the truth? "My way is the ONLY way!"
Thank you for what appears to be the only instructable on how to make a miter gauge. I'm using it now, although I will probably embed a protractor on its face.
Jul 24, 2010. 1:04 PMglorybe says:
If you set the blade height such that the teeth barely break through the material you will cause excess heat build up in the blade. That dulls blades and in the worst case can cause a carbide tip to come flying back at you. Alertness and concentration can prevent most accidents. Personality also plays a huge role. I knew one pro who constantly needed medical help from injuries. He was skilled and intelligent but had a troubled personality. Injuries broke his moods up and he was never aware but it was obvious that he wanted the injuries he received. I worked with the fellow for seven years and he needed the emergency room at least twice every year from severe wounds received on the job.
Sep 8, 2010. 8:05 PMBroom says:
Thank you for what appears to be one of the the only instructables on how to make a miter gauge. I'm using it now, although I will probably embed a protractor on its face.
Feb 23, 2011. 7:24 AMpfred2 says:
You're all wrong! hehe But seriously I've slapped circular saws using cleats to the bottom of scrap pieces of plywood and it works great.
The only beef I have with your setup is its too elaborate. Whenever I've been pressed to use this technique its always been with saw horses, or barrels, pails, milk crates are a classic with this rig too. With the old wooden milk crates just run the saw up from the bottom and you're done! They even had convenient ready made carry handles those did.
But I'm not that should criticize elaboration:
http://img178.imageshack.us/img178/2884/newshoptop.jpg
http://img294.imageshack.us/img294/2234/fenceside.jpg
http://img19.imageshack.us/img19/453/camq.jpg
As I've obviously gone to some lengths myself on this front.
Sep 9, 2010. 9:20 AMBroom says:
Yep, and I actually saw a comment on Instructables.com that was basically, "Why don't you just buy one at a store?"...!
Thanks for the reference to Steliart's version. I found it shortly after posting here, and am thinking about that.
Sep 9, 2010. 8:40 PMBroom says:
Sure, but I'm amazed they're even on this site!
Jul 7, 2011. 3:22 PMCooldeal says:
I don't think that it matters one bit whatsoever if someone does a thousand instructables like you Phil B Lutheran pastor or if they did NONE. You are using that as some kind of leverage for yourself against someone else and of course you win all the prizes and get your picture on the front page. But you're not fair to others when they see something in your safety designs and offer you suggestions. You just ask how many instructables they've posted. Because that's what y ou have going for yourself over them. They may have many more and much more clever ideas of things than you and you can't judge their comments by the number they posted or not posted.
I see so much vanity in you that I comment on just your safety issues because they are absolutely dangerous. SOME OF THEM, not all of them. I do like most of your instructables and use or modify it to my own adaptations.
Some of them are quite dangerous and I am not talking about this one although I do wish you would emphasize more caution to the potential safety of others. Product liability these days is a huge issue designed around safety and PROPER use of power equipment. Yeah I could hang a circular saw from trees with rope and tape the switch on and cut wood like that if it works. But who are we to judge what is safe or not by how many people posted instructables or not? Because I care about the safety of others I don't care what kind of scrutiny I get. If they delete my account I can get a hundred others. I am doing what is right and that is caring about others' fingers or limbs.
One man lost two fingers on a power tool adaptation and if he could be warned he said he'd pay all he had in the world to have kept his fingers from heeding a warning about doing modifications unintended by the designer of the safety of the equipment.
All of your other ideas and designs are really quite helpful and valuable and fun to read and learn. But I can't stop thinking of the one persone who follows a dangerous instructable and gets hurt. I have worked in an incredible workshop facility that is probably one of the best in the United States for over 28 years and I've seen it all and made it all. I am a professional. Junk yard rigging is for the back woods of some swamp tribe in another country. It pays to be safe and if not then send me one of your fingers. No not that one. I don't want you hurt and if it n ever happens then fine but you're taking chances with some of these modified power tool conversions.
Apr 29, 2010. 7:06 AMegbertfitzwilly says:
Thank you for this instructable. I have been shopping for a commercial table mount for a while now but can't find anything.
Also I have published a couple myself, I feel your pain about the ability of some readers to obsess on petty incidental risks. I think the 'flag' button on comments needs a couple more entries like 'Already asked and answered' or perhaps "What a marooon...."
Mar 9, 2010. 8:40 PMkulin62 says:
Phil, thank you very much for all the comments and guidance. Thanks for the effort. I will post pictures of the saw table when I am done. With best wishes and blessings, Kulin
Mar 11, 2010. 10:57 PMkulin62 says:
Thank you Phil for the comments and suggestion. This idea had come to my mind and I was going to attempt it after assembling the table. I plan to work on 1/4 inch thick pine lumber a lot and hence the risk of something falling down. I will definitely make a Masonite insert for the slot. Thank you again for all the effort. With best wishes and blessings. Kulin
Apr 25, 2010. 1:07 PMsteliart says:
I have tried your miter gauge design with some additions and with the use of some different material (that I had) and I can say it works good. You can see it in myinstructable.
Apr 26, 2010. 12:39 PMsteliart says:
Actualy I had the same doupts if the plexiglas will hold, but it proven to be very strong and flexible enough to allow me to add the protractor and and a scribe a line to it.
Mar 3, 2010. 5:11 AMhardlec says:
With minimal space and funds, a saw that does double duty is a great idea.  Is it possible to make this table accept a "jig saw" or Saber saw as well?  Even better a triple threat with a circular saw, a sabre saw and a router.
Jan 9, 2010. 11:22 AMaeray says:
Excellent. I toyed with this idea a few years ago, going as far as sketching up some designs, but in the end time constraints forced me to buy a "benchtop" saw. Funnily, my old abused Skilsaw still runs like a champ with very little maintenance, but I just had to spend $250 to replace the armature, bearings, and brushes on my benchtop saw.
1-40 of 79next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
406
Author:Phil B
I miss the days when magazines like Popular Mechanics had all sorts of DIY projects for making and repairing just about everything. I am enjoying posting things I have learned and done since I got my...
more »
