You can make it from parts found in the hardware store and garage sales.
First you need to know some navigator and sundial facts. As the Sun travels across the sky daily its astromonical position is called "right ascension"
This Sun Tracker will move the position of a solar array, heliostat or solar furnace as it makes its daily trip across the sky.
The other change your collector has to make is its altitude which changes as the season changes. This adjustment can be made on a weekly basis, and an automatic adjustment isn't usually necessary.
I will keep you up to date with the progress of my prototype equitorial mounted solar furnace with more pictures and add ons.
I felt the neccesity to publicize the Strong Simple Solar Tracker as an inspiration to anyone else that might be thinking about building a large solar furnace, but were intimidated by the tracking drive.
Now that you know you can make one cheaply and quickly, maybe you'll be tempted to take the plunge.
Solar Tracker 92908.pdf(612x842) 264 KB
Remove these ads by
Signing UpStep 1Look Ma, no solder!
They are http://www.youtube.com/watch?v=uhKYvwl86pA
and http://www.youtube.com/watch?v=0-bj0guW0k0
(Just watch that one for the liquid piston tracker)
I think it just needs some simple electronics for it all to work, it is all time based (you do not need to find the sun or have any photocells ), and seasonal adjustment is manual and is marked on the side of the tracker.
Brian
By toggle switch I mean like
= =>--0--<= =
the '<' are the switches (or the light sensors) and represent the 2 possible positions of each switch (ON or OFF), and the '===' would be to the positive and negative leads from the power source. '0' is the motor.
http://www.instructables.com/id/Heliostat_experiment_and_finding_true_north_with_e/
http://www.instructables.com/id/Clock-Based-solar-tracker-experiment/
Just a thought
"Vilitas, simplicitas, efficitas" should be part of every engineer's creed.
(Hey, will someone out there please nit-pick my dog-latin for "Cheapness, Simplicity, Effectiveness"?? I'm designing a family crest...).
-- Does it work on cloudy, or partly-cloudy days?
-- This is single-direction only, right? So the mount must be manually returned to the start position at the end (or the beginning) of the day.
-- Electrical tape isn't a great solution for outdoor circuits (in fact, it's use in general is fading.) You can find other threaded sockets with wire connectors (like lamp sockets), or maybe re-use a cheap worklight--which would have a sturdy cable already attached.
