3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
A Stylophone
A Stylophone
I was browsing through the Instructables technology area the other day looking at musical circuits, and I noticed that there was a project that was missing...  The good old fashioned Stylophone.
There are a couple of wonderful examples that were there in the spirit of the original (with even better features), such as the Tic Tac Tunes , and the NoiseAxe Minisynth, but I couldn't find an original PCB based keyboard, using good old fashioned analog electronics.
So I made one!
This Instructable will show you how to make your own original stylophone - The schematic that this is based on is my own, so it is free from Intellectual property restrictions.  It is based around a 555 timer (so it could be an extension of the recent "Know Your 555 timer" article), and uses an ubiquitous LM386 audio amp so it can have enough volume to stand out from the crowd.
As with all of my projects, the PCB is designed for etching yourself, and there are no components that are difficult to source - in all, the Stylophone can be constructed for less than about $30AUD.
There is a breadboard area on the PCB, so you can add your own tremolo, or even an AtMega168 chip if you feel inclined.  Allowing you to create the ultimate in digital analog fusion!!!! (Sorry - I couldn't resist)   :-)
Update:  I just downloaded a video onto youtube. Click here to view it.
Step 1That 555 is connected is a way that is weird!
The heart of this project is the wonderfully versatile 555 timer, configured as an Astable Oscillator (An oscillator that continues to provide output pulses as long as it is turned on.)
If you look at the circuit for the original Stylophone, you will see that the 555 has a diode and transistor hung off the discharge line (pin 7).  These additional components ensure that the output waveform has a duty cycle of 50%.
In a standard configuration, a 555 allows for the timing capacitor (C)  to be charged via R1 and R2, but discharged using a separate discharge pin (pin 7) only via R2 - this means that the cap charges using one path, and discharges using a different circuit path, resulting in an output that may not spend equal amounts of time being High and being Low [ie the output does not have a 50% duty cycle.]   This is especially true when one of the resistors is being changed to change the tone.
I will admit that I am unsure why the original designer was worried about the duty cycle - remember that this instrument produces square waves - they are a *rich* source of harmonics..
I found a cool way of connecting the 555, that ensures that the duty cycle is 50% using a much simpler configuration here.  Essentially, the oscillator is connected so that the normal 555 discharge connection is not used.  Instead, this circuit uses the output pin to both charge, and discharge the timing capacitor, ensuring that the duty cycle is kept at 50%.
The frequency of oscillation can be adjusted by varying the voltage on the Control Voltage pin (Pin 5) - this allows the Stylophone to be tuned to other instruments.
Awesome!
64 comments
1-40 of 64next »
Oct 10, 2011. 9:54 PMCamryn89 says:
(removed by author or community request)
Jul 6, 2011. 7:04 AMJimmimak says:
I really like this, I took apart one of the "reissue" stylophones and the 555 still exists in the design, but another glop top chip is used to add envelope and vibrato to the sound.
Anyway, I have a question - I want to make one of these but instead use a piece of resistive material with the stylus as the "wiper", like in a variable resistor, so the frequency is continuous rather than stepped, can you recommend anything to use? Alternatively, can I use a fixed resistor and use some sort of variable capacitor? Thinking about theremins...
May 20, 2011. 6:31 AMvhelminen says:
Hi !
I'm building one for myself (so thanks for schematics etc. ! :) ) but all I have for speakers/buzzers are rated as 8ohms 0.5W little speakers. And I have two of them...
Is the LM386 able to power up the both speakers ? Or can I use only one ?
Much appreciated if somebody answers me, peace.
Jan 26, 2011. 9:32 PMrenegade_turkey says:
I have a question. Does 4k7 = 4.7k ohms? Thanks!!!
May 8, 2011. 3:02 AMjamiec53 says:
Yes, it's just another way of writing it :)
May 1, 2011. 1:16 PMapaterson1 says:
is the difference between the ohms of the resistors consistent i.e c-c# is 5000 and g-f 1500 ohms?
May 3, 2011. 12:12 PMapaterson1 says:
is there any sort of pattern in the resistor ohm-age so i can extend the octave range?
May 7, 2011. 6:45 AMapaterson1 says:
yeah that'd be very nice i'd like a 4 octave range thanks
Jan 27, 2011. 10:15 PMa_merlino says:
Got the circuit working on a breadboard and wanted to make it permanent. Just finished up and I'm having some troubles. I checked the entire circuits connections trying to find a mistake. I can hear the circuit when I flip the switch because I hear a little noise, but after a second the circuit dies almost like a capacitor was discharging. When I get lucky I can play a note or two and it sounds great but then dies. Maybe I burned something up when I was soldering? Any suggestions of help?
Thanks
Jan 17, 2011. 8:51 PM7654321 says:
Is there an alternative to coating the keys with solder? I'm not too handy with a soldering iron and dont want the keys to come out ugly.
Jan 12, 2011. 8:31 AM-Desiree- says:
Hi I'm a 2nd year Electronics Technology major and I'm looking for a good project for one of my classes. Would I be able to make this? I don't know how I would make a board like that.
Nov 4, 2010. 10:11 PMbman114 says:
try using acetone, and the toner will realease with minimal effort. Less elbow grease and less chance of damaging the copper.
also Harbor freight has an in expensive laminator.$20 or less
Dec 31, 2010. 1:41 PMseandogue says:
Dec 31, 2010. 5:06 PMseandogue says:
Ah...ok, thanks.
Dec 18, 2010. 8:32 AMflof says:
Do you really use a 0.05uF Polyester cap?
I can't find this one on jaycar nor on a local shop. The closeset I can find is 47nF.
Also would a X7R 10% ceramic cap work?
Dec 18, 2010. 2:18 PMflof says:
Thanks!
Time to etch a pcb and order parts :)
Nov 18, 2010. 4:20 PMthe_prototype says:
I would love to make myself a "mini"-stylophone, but I hate making PCBs x_x
Dec 14, 2010. 4:50 PMgamez222 says:
can you send me the PCB of this... I want to make one for my little as a gift for Christmas. Here is my e-mail.
gamez222@yahoo.com
thank you in advance.
Oct 14, 2010. 2:35 AMyaang says:
I don't like the stylus, i know you tried to make it close to the original but then why did the original designer made it the way it is ? Wouldn't it be more practical to turn them into something more like regular keyboard keys ? That ticking noise everytime you hit a note annoys me.
Also a question, from what I understand you can only play a single note at a time because all the resistances are serially connected right ? What I'm getting at is wouldn't it be better if we used individual resistances for each note so you can play more than 1 note at a time.
Am I taking this out of context and re-inventing the keyboard ?
Nov 18, 2010. 4:24 PMthe_prototype says:
it would be easy to make one without ticking noise, and playable with anything you like!
Just take a bit of sturdy plastik, make contacts for the keys and glue it over the keys with just a little space, so when you tap on it the contact will touch the key and voilà ther's no ticking noise and you can use whatever you want to play it with :)
Dec 14, 2010. 5:24 AMcodongolev says:
alternatively, you could connect the contact wire on the stylus to a bit of steel wool. just make sure it's not the real thin kind that'll start to burn when you use it.
I'm planning on making a flexible stylophone out of duct tape. it'll be pretty great (and much easier to do than the giant stylophone I mentioned earlier). I already have a flexible keypad for it, but I just need to put the components on a small board.
Nov 27, 2010. 9:09 AMAndyGadget says:
I don't know how I missed this when you first published it - Brilliant! - Really in the spirit of the Original Stylophone.  Great video too.
I well remember the Stylophone TV ads in the early 'seventies featuring your fellow countryman Rolf Harris.
(And thanks for the Tic Tac Tunes mention.)
Oct 12, 2010. 5:12 AMcodongolev says:
idea:
make a gigantic stylophone. wouldn't be that hard, just use metal tape for big ol' contacts.
then, make a place to attach a guitar strap.
lastly, make a glove with a metal contact on the finger that is attached where the pen would be.
bingo. stylophone keytar. I call it the stylokeytar. I think if I get any funding for it (I'm a bit short on cash, maybe christmas will help) I'm going to make an instructable.
Oct 16, 2010. 2:36 PMcodongolev says:
I, unfortunately, am very new to electronics (I haven't made really anything more than blinky lights until this year, and I just started taking a digital electronics class) so I don't really know how to do any of that. however, I hereby gladly give anyone who wants to make one permission to do so (just give me some credit ; ) ). I do know how to use 555 timers now, though (fun little electronics learning kit from thinkgeek, solar theremins are pretty sweet) so I'd be able to make it pretty easily.
Oct 27, 2010. 4:33 PMScubaSteve says:
This sound interesting, and i plan on taking it up. Im thinking about adding some extra filters and oscillators to the output for a more varied sound.
Oct 28, 2010. 6:35 PMmoshee says:
Maybe try starting out with a third potentiometer for duty cycle? I wonder how easy that would be to implement?
Oct 29, 2010. 4:38 PMScubaSteve says:
It wouldint be that hard...Im going to use a slide potentiometer for the tuning. I wonder if i could make it polyphonic by doubling up the circuit and using a 556...that could let me play 2 tones at the same time.
Oct 18, 2010. 6:26 AMJodex says:
I think this is really great instructable. I am going to make a synth according to that schematic, by which I mean that I'm gonna put little buttons to be a keyboard, and maybe add some filters or do some little circuit bending so I can get more than just the square wave. I might post a video of it to youtube, if i remember. I can link it here then if you want.
The greatest thing, which I really appreciate, is that you have put those resistor values to get the right tones. I could not do that myself propably.
Awesome, 5/5 definately.
Oct 18, 2010. 6:21 AMLukaR says:
What about adding a barrel power jack to be used with a 9V wall wart instead of the battery? Then you could replace the switch so you don't have to hold it down all the time.
Oct 2, 2010. 3:48 PMCoolKoon says:
This thing's just great! I mean EVERYONE knows what's the 555 timer circuit for, but I couldn't come up with this idea in a thousand years (of course I didn't know what's a stylophone either :P).
Let me ask you some questions though: this is the first time I hear about this press-n-peel thing (only worked with the toner transfer and the UV-based resists). How does this work? I mean I get the fact that you print your pattern on this film, then iron it on the board, but does this result in a positive transfer? And what kind of material is this press-n-peel thing from? What makes sure that only the printed areas are transferred?
As for the component soldering, you seemed to have the regular components mounted on the board in a SMD fashion. Why is that?
Also, if you're lazy or just don't want to get your hands wet after etching the boards using the toner transfer method, you can use acetone (or any of the stronger polar solvents) to remove the residual toner from the board.
1-40 of 64next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
361
Author:drj113
I have a background in digital electronics, and am very interested in computers. I love things that blink, and am in awe of the physics associated with making blue LEDs.
