A Word Clock
Step 6PCB layout, Overlay and Schematic files
To make construction simpler - here is a PDF of the PCB layout and component overlay.
[Update - 21Dec2009] I have updated the PCB file to allow construction of a 6 inch x 6 inch (150x150) display.  This allows construction on commonly available (in Australia) board stock - I have also repaired a layout fault that resulted in a misalignment with the headers and the pcb mounts.
You will need to scale the output to get the PCB to be the correct size!
The file uploader mucked around with the resolution of the schematic making it difficult to read - I have uploaded a PDF of it, so people can see a high resolution version.
I have been asked for the parts list. Here it is:
U1 PIC 16F877
U2 78L05
D1 1A Bridge
D2 1N914
D3 5V1 Zener
D4 1N914
D5 1N914
D6 1N914
D10-D126 5mm Blue LED
X1 4Mhz resonator
All resistors 1/4 watt
R1-R24 470R
R25 10R
R26 10R
R27 4K7
R28 4K7
R29 4K7
R30 4K7
R31 10R
R32 100K
R33 4K7
R34-R77 470R
C1 100uF/25V
C2 10uF/25V
C3 0.1uF
Q1-Q24 2N2222, BC547 etc
J1, J3 2 Way PCB terminal Block
J2 3 Way PCB terminal Block
J4 5 pin header (0.1)
PB1, PB2 Momentary Action Push Buttons (Time set)
B1 4.5v Battery Pack (3xAAA Cells)
XFRMR 1 7.5V AC / 400Ma Transformer
Display PCB
Controller PCB
Stencil PCB
4x 3mm screws
2x 10mm spacers
11 30mmx170mm PCB Strips (Light Baffles)
25 30mmx15mm PCB Strips (Light Baffles)
40 Pin IC Socket
Hot Melt Glue
I have also added the 'C' Source code as a download.
Several people have asked for the original source PCB layout file - I have attached it - It is *NOT* in eagle cad format - it is in express PCB format - A PCB drawing tool that is free of charge from express PCB. I hope it is useful to you.
44 comments
1-40 of 44next »
May 13, 2011. 8:46 PMEmanuelg says:
Hey. im 15 years old and i'm wanting to make this project at school. I live in New Zealand :) and i'm wondering how much the whole thing costs. I have a budget of $60 nz dollars. p.s useful nz electronic sites are jaycar nz. cheers :)
May 20, 2010. 8:40 AMritchie56 says:
this is really cool and I like the stencil on the back design as well. How about this for another alternative - box each letter separately, that way you can have words running diagonally and even vertically. It would look like one of those circle the word puzzles. You could even have a crossword themed clock. the bluish-green glow made me first think it was EL - nice effect!
May 19, 2010. 5:22 AMytumer says:
 When you printed the WordClock-Stencil.pcb to a pdf file how did you manage to invert the colours? i.e. make the letter white and the background black.
cheers
Oct 5, 2009. 5:12 AMPatrick.Firganek says:
another question: did you use low current LED's oder normal LED's?
May 19, 2010. 1:30 AMytumer says:
 Hi Doug! Just ordered my PIC programmer today and I'm now thinking about which LEDs to use... you said you use 16000mcd flat top LEDS, would 16000mcd be a little too bright for home use?  I know your's stays at work under bright light.
Is 6000mcd ok or should I be looking for 12000mcd LEDs?
Thanks in advance!
P.S. my first instructables build :D
May 19, 2010. 4:38 AMytumer says:
 Cheers for the prompt reply Doug, really appreciate it.
Mar 31, 2010. 3:57 AMakhilbhas says:
Can you send me the hex file to my id or upload it in the site?
my id is akhilbhas@gmail.com
Mar 26, 2010. 7:39 AMboozo says:
hey i noticed that some of the led in the display psb is not connected like the r,u,n,e,z,l and the line from the j4 prog to the r27 is not complete plz help me .. and i read you have made a update to your new psb i couldn't find it anywhere .
Mar 21, 2010. 6:32 PMakhilbhas says:
i cant download those files .............pls help
Mar 22, 2010. 5:59 PMakhilbhas says:
i'm new to this site ....thanks for your help............... now i need htc.h header file i cant find it any where
Mar 8, 2010. 12:36 PMtheladyk8 says:
So how much PCB stock should I order total? (To include the baffles and the base..)
Thank you! :)
Dec 16, 2009. 4:27 PMbignin says:
Thank you for the great post.  I would just like to know what the final dimensions are for the clock? (either english or metric works)
Thanks again.
Nov 11, 2009. 10:09 PMretrac.noremac says:
this is such a cool clock concept
i would love to have a watch like this
Oct 22, 2009. 5:23 AMPatrick.Firganek says:
hello,
my LED's arrived and built them onto the display board. mainly it works, but some words like half or to,... do light a little bit. I tryed to replace the resistor for the LED's to 220ohm but it doesnt worked. I changed the transistors BC547C and then 2 words stopped lighting. But there are always some words that wont stop light. What shall i do? I searched for short cuits on the layout ,but its all right.
What could that be?
greetings
Oct 23, 2009. 12:05 AMPatrick.Firganek says:
no no, you didnt understand. The program and the microcontroller works perfect. But all words with !2! LED's do light a little when they should be off. When they should be on then they do that. Its like the BC547 is in work-mode but the microcontroller does give a LOW level. This means there should be a shortcurt at the transistors. But there isnt.
Oct 26, 2009. 4:52 AMPatrick.Firganek says:
ok the problem is solved. the transistors were soldered wrong. the collector has been been on ground and the emitter on the LED side. I switched them and now it works perfectly.
So now i can go over to the case. I will put this all into a wood case and then take a plexiglas panel for the front. On this plate i will spray the letters.
At the moment im working on a board for the transformator, which is placed in the box, too.
I will keep you guys up to date :)
Greetings
Oct 20, 2009. 2:14 PMrayads786 says:
 Hi, i've downloaded express PCB and tried to print the PCB onto some acetate so i can make the PCB at home but i cant get it to print at the correct size!
any suggestions
Oct 18, 2009. 4:33 AMwham29 says:
Doug, I'm having troubles opening up the rev 2 Schematic. Is there anyway you can make it a PDF file?
Oct 19, 2009. 2:30 PMwham29 says:
Doug you are the man.  I recieved the new schematics.  Thank you.  Now i'm almost complete, just wanting on some parts.
Oct 19, 2009. 9:50 AMwham29 says:
I'm still having problems. could you maybe e mail me directly with a copy?  It's wjhammer29@hotmail.com.  I'd really appreciate it.
Thanks,
Wes
Oct 13, 2009. 1:08 PMchile19 says:
Doug, what program do you use to make the .pcb file? I use PCB Wizard and it can`t open it.
Thanks
Oct 7, 2009. 6:27 AMrajf says:
Love this project, exactly the type of clock I've always wanted. Its been years since I've done any electronics but if feel this is worth the experimentation.
Just ordered my PIC programmer and am doing some serious reading to understand what the hell to do with it!
Thank you for the detailed write up.
Oct 5, 2009. 10:05 AMscorpio41 says:
Nice work Doug ! This is going to be my first Instructables "make" Just one question :- On the schematic, you show a 4K7 going from the base of Q20 to I presume the positive rail, why does this transistor need the extra bias ? Regards Lee
1-40 of 44next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
344
Author:drj113
I have a background in digital electronics, and am very interested in computers. I love things that blink, and am in awe of the physics associated with making blue LEDs.
