Introduction: AUTOMATIC JUICER MACHINE( FLOW RATE CONTROL THOROUGH ARDUINO)
THE BEST MACHINE THAT MONEY CAN BUY
Step 1: STEP 1: GET THE MATERIALS
THE FIRST THING ,YOU HAVE TO DO IS TO GET THE MATERIALS
LIST
2 BOTTLES 1.5 LITERS
ARDUINO UNO
2 SURVO MOTORS
ONE DC MOTOR ( SCAVENGE IT FROM A DRILL MACHINE AND GET IT RPM CONTROLLER OR USE A POTENTIOMETER)
2 LONG PIPES EQUAL LENGTH
next
Step 2: STEP 2:PLACEMENT
PLACE THE TWOO BOTTLE ON A WOODEN BOARD AT EQUAL HIEGHTS
THEN ,ADD WATER INTO THEM .
USE A TIMER TO MEASURE HOW MUCH TIME IS 100ML OF WATER TAKING TO FLOW FROM THE BOTTLE TO THE BEAKER. MEASURE FOR BOTH THE BOTTLES .DO USE WATER FOR ONE BOTTLE AND ANY OTHER FLUID FOR ANOTHER BOTTLE AND MEASURE ITS FLOW RATE , THEN MEASURE THAT HOW MUCH WATER GOT ADDED IN THE BEAKER IN 1 SECOND.
THATS IT YOU MEASURED THE FLOWRATE NOW THE ELECTRONICS PART.
Step 3: STEP 3: ELECTRONICS
USE AN ARDUINO UNO AND THE 2 SERVOS AND ATTACH THE SERVOS TWO THE TWO BOTTLE CAPS WHICH CAN GET FIXED FROM ONE SIDE AND GET OPENED AS THE SERVO MOVES.
NOW ATTACH THE SERVOS PINS
POWER PINS ARE RED(5VOLTS) AND BROWN(0 VOLTS)
AND ORANGE SIGNAL ATTACH IT TO PIN 9
AND THE OTHER SERVOS TO PIN10 OF ARDUINO.
NOW THE ONLY THING YOU NEED IS THE PROGRAM.
ILL UPLOAD IT SOON , OR YOU CAN DOWNLOAD THE REPORT OF THIS PROJECT THE RTF FILE.
Step 4: STEP 4: DC MOTOR MIXING AND RPM CONTROLLER
NOW WE HAVE TO ATTACH THE MIXER WHICH IS EASY FOR ANY ONE TO DO , JUST LOOK AT THE DIAGRAM BUT THE MAIN PART IS POWER TO THIS SYSTEM,YOU HAVE TO GET A BATTERY AND A SOLAR PANEL AND MAKE A SOLAR PANEL CHARGING CIRCUIT , JUST CONNECT THE PANEL WITH A DIODE DIRECTLY TO THE BATTERY.OR MAKE A CHARGE CONTROLLER.AND FROM BATTERY YOU NEED TO GET A WIRE WHICH GIVES 9 VOLTS , THIS IS EASY, JUST TAKE A BATTERY OF 12 VOLTS AND ADD SOME RESISTORS OR USE LM7805 OR LM7809 IC AND YOU CAN GET A 9 VOLT SUPPLY FOR ARDUINO .NOW CONNECT THE ARDUINO WITH 9 VOLT POWER AND THE DC MOTOR DIRECTLY TO THE BATTERY.
THERE YOU HAVE IT NOW THE LAST THING IS TO PUT THE PROGRAM IN THE ARDUINO AND THEN START MAKING SOME BEVERAGES BOYS AND GIRLS
FOR ANY QUERIES DO CO
Step 5: VOTE FOR ME GUYS IF YOU THINK I DESERVE TO BE IN THE TOP 10 .
FOR ANY QUERIES DO CONTACT ME
Coded Creations
Automation Contest
