1. Since your car engine is running to charge the AC system there are moving belts and pulleys,fan(s) and very hot parts. You can easily loose your fingers if you put them where they don't belong!
2. Freon if sprayed as a liquid on your body parts will freeze them instantly- FROSTBITE
3.Don't release freon into the atmosphere. It is not good for the earth.
4.Wear safety goggles at all times incase a hose blows or something goes wrong and freon is sprayed on your face.
5. If after reading this instructable you feel unsure about doing this then you should not be doing it.
THIS CAN BE DANGEROUS AND THERE IS POTENTIAL FOR INJURY. I ASSUME NO LIABILITY FOR YOUR TRYING THIS. THIS IS JUST A DEMONSTRATION OF HOW TO DO IT. IF YOU DECIDE TO DO IT YOU DO SO AT YOUR OWN RISK.
Ok lets get started.
Tools needed:
1. The adapter to connect from the freon can to your freon SUCTION SIDE of the AC system.
Found where you buy freon.
2. Freon- probably 2 cans if your system is barely cold. If it is cool but not as cold as it was buy 1 can
3. A thermometer
4. An AC system in need of some freon.
Remove these ads by
Signing UpStep 1Install the hose on can
AS LONG AS THE CAN IS UPRIGHT ONLY VAPOR COMES OUT OF THE HOSE
IF THE CAN IS UPSIDE DOWN LIQUID COMES OUT SO KEEP IT RIGHT SIDE UP!
I spent a lot of time on this simple step but that was so you do this SAFELY.
My intended audience for this was folks who wanted to get their system going but really did not understand what was going on behind the scenes. Nine times out of ten if you walk into a parts store and ask the counter guy "I need some of that stuff that makes your AC cold" The guy will say "you mean freon and its over there." Freon is the accepted street name if you will and most people recognize That name. Take a look at this big chain auto parts seller's web page and see how they identify refrigerant on their web site
http://www.autozone.com/N,101308/shopping/accessoriesLanding.htm
