Remove these ads by
Signing UpStep 1Having the idea
The reason is quite simple: I am bored of empty batteries (Ipod, mobile phone) while I'am on the go. And the solution with the linear regulator like the "7805" is in fact very simple, but very unefficient, because: firstly you need a supply that provides about 3 volts more than you need for usb and secondly in most cases the difference between input voltage and output voltage is lost in heat.
The solution for the problem comes from Linear Technology. The most important compenent of the cicuit presented in the next steps is the "LT1301". This is a small step up converter for to build switching mode power supplys with only a few external components.
Thanks for help.
Please help.
Look a standard cellphone battery has around 900 mAh at 3,6 volts. 2 standard AA cells or AA rechargeable batteries have aroound 2,4 to 3 volts at 2000 mAh. the charger has an loss of 10%... This will be enough for one and a half charge!
guide:
http://www.instructables.com/id/Ipod_Touch_Charger_100_works/
LT1301CN8
LT1301CS8
LT1301IN8
LT1301IS8
are they all compatible or is there a certain one to get?
(http://www.linear.com/samples/orderSamples.jsp?navId=H0,C1,C1003,C1042,C1031,C1060,P1450)
VV.core.
http://www.instructables.com/id/Solar-Cell-Phone-Charger-made-from-old-parts-and-a/
http://www.instructables.com/id/Make-A-Handheld-Solar-Power-Supply/
I have a 6v 100ma cell. How/could you wire the solar cell to this?
Thanks!
