Bigger is cool looking... But not always better. I have found smaller more robust designs to be far more fun that the gigantic heavy cannons. I can recharge (with a foot pump) and reload in less than 30 seconds and hold this thing much easier than its heavy breathing counterparts. Other than this design, I no longer build using PVC as it does fail catastrophically.
I made this particular cannon to be used for physic's demos for middle and high school physics students. 2l bottle fail at surprisingly high pressures (relatively) and have served as a reservoir very well.
Remove these ads by
Signing UpStep 1Parts List
1 2l bottle of soda - minus the soda and washed out
1 .75" sprinkler valve with manual switch
1 45 elbow
2 female/male 90 elbow
1 female/threaded adapter
1 end cap
1 .5" thread-> .25" threaded bushing (mine is galvanized)
3 1.5" long pieces of pipe
2 2-2.5" long pieces of pipe
2 .5" female - .75" threaded adapter
1 4 wayfitting
1 Tire Stem with schrader valve (walmart or autoparts store) - home depot did not have this item
PVC cement
Teflon Tape
1 male threaded cap OR 1 gauge (might be listed as manometer)
Optional Add on (for bypass and a later project)
3 more 1.5" tubes
1 ball valve
1 45 elbow
1 3 way Tee
"These high pressure air weapons can shoot things fast enough to cause severe injuries or death. Never use them to shoot things at people."
Because the math states the reservoir is too big for a reasonable length barrel.
soda bottles are really dangerous when they explode, and damage your hearing alot. overpressurize this and you will get holes in u.
Damage hearing, sure - if it ruptures... "Holes?" Not likely - this is why I pressure any pressurized device I make while filled with water. Luckily, overpresure for a PET bottle is in excess of 120psi.
use five bucks and make a one foot long, 2 inch diameter pvc chamber that you can get up to 120 psi insted of the little 20 psi you have in that bottle.
That would be about 1/5 the volume and about a quarter of the energy at the pressure's I run... I run at 90 psi max - various resources claim soda bottle failures ranging from 120-180 psi - and I'm okay with running a 1.33 safety factor with this sort device.
Really, I find 40-60psi the optimal zone for water bottle rockets. More than ~40psi tears ketchup packets before they get out the barrel.
also, why dont u make a differnet desighn to make it easier to hold?
Hey now, don't knock it until you've tried it. It's not only easy to hold, it's intuitive to new people. One hand on the valve solenoid (easy access to the trigger) and the other on one of the back.
All that said... I published this in mid 2006 - I build the first one in early 2006 and the second one shortly before publishing. Since then, both have fired literally hundreds of water bottle rockets (and the occasional ketchup packet). It's been highly successful, reliable and aesthetically pleasing. And since it's got more than just PVC pipe, police officers have either liked it or taken no interest (both good for questionably legal devices).
