DIY Air Heat Exchanger - Made From Soda Cans and Pvc Pipe
12,418
118
Posted in WorkshopEnergy
Introduction: DIY Air Heat Exchanger - Made From Soda Cans and Pvc Pipe
About: I like to make stuff in my free time. Especially programming, cooking, electronics etc. Lately I'm making tutorials about stuff I made the last few years.
You will learn how to make a low cost, easy to build and very effective air heat exchanger by using soda cans, pvc pipes and some computer fans.
The purpose of the heat exchanger is to ventilate a room or house with fresh air while not loosing to much heat.
In winter times we want to have a comfortable indoor climate while not wasting to much energy on heating and ventilating.
The heat exchanger heats up the cold fresh air with the hot air that is be replaced before entering the room.
The heat exchanger can be used in hot climates as well to ventilate air conditioned rooms or houses.
More info, videos, and updates can be found on my website.
tomtomheylen.com/categories/DIY/Air_heat_exchanger.php
Step 1: Video
Step 2: Low Cost Yet Very Effective Air Heat Exchanger
Step 3: How It Works
The air heat exchanger consists mainly of an aluminum pipe made from soda cans that sits inside a wider pvc pipe.
The cold fresh air is being pushed trough the aluminum pipe to entering the room.
The hot saturated air is being pushed trough the pvc pipe in the other direction to leave the room.
Since aluminum is a very conductive material, the heat/cold will be transferred upon each other while keeping the fresh air separated from the saturated air resulting in fresh air entering the room without loosing to much heat.
Step 4: Material List
1 Pvc pipe
L = 2m (6.5 ft) dia. = 7 cm (2.7 in)
2 Pvc Y-piece
Dia. = 7 cm (2.7 in)
3 Pvc pipe
L = 1 m (3.2 ft) Dia. = 5 cm (1.96 in)
4 Pvc 90 degree elbow
5 Pvc Pipe reducer
7 cm (2.7 in) to 5 cm (1.96 in)
6 Soda or beer cans
7 Pc cooling fan (2x)
7 x 7 cm (2.7 x 2.7 in)
8 Polystryne board (2x)
10 x 10 cm (3.9x3.9 in)
9 Alu or multi purpose glue or epoxy
10 Glue gun
11 Foam sheet
ep. +/- 5 mm (0.9 in)
12 Adaptor
220v or 110v ac to 12v dc (min 0.3 A)
Old router, shaving machine, pc power supply,...
13 Electrical wire
14 Switch
Step 5: Putting It All Together
We use a can opener to open up the top of the soda cans. About 12 or so cans is what we need. Together the length of the cans should be a bit less then the length of the outer pvc pipe.
Step 6:
Use a drill with a 10 mm steel drill bit and bore 5 holes in the bottom of each can.
Calculating the total surface of the bore holes in the bottom of each can
The total surface of the holes should be equal to the space between the two pipes.
To calculate this I use an example with a drill bit of 10 mm.
The big pvc pipe has a diameter of Ø 70 mm (radius 35 mm). The soda cans have a diameter of Ø 66 mm (radius 33 mm).
Area pvc pipe = π r2 = 3.1415 . (35 . 35) = 3848 mm2.
Area aluminum pipe = π r2 = 3.1415 . (33 . 33) = 3421 mm2.
Now we subtract the aluminum pipe from the pvc pipe.
3848 – 3421 = 427 mm2.
The holes we bore in the bottom of the cans should have a total of 427 mm2.
We calculate the surface of 1 hole with a drill bit of 10 mm (radius 5 mm).
π r2 = 3.1415 . (5 . 5) = 78 mm2.
Now we divide the 427 mm2 by 78 mm2.
427 / 78 = 5.4 rounded to 5
So we need to bore 5 holes with a drill bit of Ø 10 mm.
Step 7:
Now glue together the bottom to the top of each can with the aluminum glue. I used 2 strips of wood to lay the cans on to make sure the pipe is 100 % straight.
Step 8:
With a grinder or metal saw cut 1 piece of 20 cm and 2 pieces of 10 cm from the Ø 5 cm (1.96 in) Pvc pipe.
Step 9:
Put one end of the 10 cm pvc pipe in the opening of the top can from your aluminum pipe and glue together to make sure there are no fits.
Step 10:
Let everything harden out and respect the hardening time as subscribed on the glue you are using.
Use a grinder of metal saw to cut the Ø 7 cm pvc pipe at a length of 170 cm.
At one end of the pipe, cut away diagonally a piece about 10 cm long. This is to prevent rain or snow getting in to the pipe.
Glue the pvc y-piece on the other end of the Ø 7 cm pvc pipe.
Step 11:
Cut a bunch of stripes of +/- 1 cm width and +/- 15 cm long out the foam sheet.
When your aluminum pipe is hardened out, glue on each can 2 stripes diagonally over the can on both sides. Make intervals of 45° on each can to make sure the air can travel trough the pipe.
Step 12:
Now it's time to slide the pipes in each other.
Gently slide the aluminum pipe with the pvc end in the larger pvc pipe starting at the y-piece.
Now glue the pvc pipe reducer to the end of the aluminum pipe and slide it in the y-piece.
Glue the 20 cm small pipe to the reducer and the pvc elbow and the 10 cm pipe to the other end on the aluminum pipe.
Step 13:
Your heat exchanger is nearly ready now.
In center of the polystyrene boards, cut out a circle with a diameter of 5 cm.
Glue the fans to the center of the boards with you glue gun and glue one board to the opening in the y-piece and the other to the opening of the Ø 5cm pipe near the elbow.
Step 14:
The last step is connecting the 12v dc adaptor to the fans.
Warning!
Working with electricity can be dangerous.
If you're not familiar with electrical circuits, get an electrician to do the last step.
Connect the adapter with the electrical wire and the switch in parallel to the fans. Make sure to get the positive and the ground right.
Your air heat exchanger is ready!
Step 15: Installing
The best place to install your heat exchanger is under the roof since that is the warmest place in the house.
In case you using it to keep your house cool, install it down the bottom of the house.
Step 16: Extra Info
For larger houses or rooms, the heat exchanger can be made longer with stronger fans.
Do you have suggestions or comments on this project, please feel free to leave a comment in the comment area.
Did you like this instructable? Please click the FAVORITE button and FOLLOW ME for more awesome instructables to come.
Thanks for reading,
Tom Heylen
    • Spotless Contest
      Spotless Contest
    • Trash to Treasure
      Trash to Treasure
    • Microcontroller Contest
    2 Comments
    Could you replace the soda can tube with an aluminum dryer vent hose? being thinner, I thought it may transfer more heat
    A useful result to remember. For 2 co-eccentric circles to have equal area, the outer circle has to have sqrt(2) times the diameter of inside circle.
