Aliens Powerloader Halloween Costume
Here's a step-by-step view of how I built one of the most memorable pieces from modern sci-fi...the powerloader from Aliens.
I built this costume for my girl (dressed as Ripley) to wear at our Halloween party. I used a 1/12 model kit to get dimensions and used a ton of reference photos I found on the web. Between the fact that she's 5-1 and that I wanted her to get under our 8' ceilings I scaled the loader down to about 80% actual size - with a few adjustments here and there. Everything was built completely from scratch except the beacon light on top and the 4-point racing harness. Total time spent building: about 180 hours over the course of 10 weeks.
I am missing photos for a few steps (like the wiring) but the comments I received on my Slideshow convinced me this should still be a full instructable.
To see a clip of the loader in action:
UPDATE: G4's Attack of the Show gave a nice little shout out to the costume and the instructable! (jump to 1:20)
Step 1The Foot
The Foot
The beginning of it all...the foot. I determined this ice cube bucket from Target was sturdy enough under foot and a good starting shape. A 2x6 was used as a stable base and a couple pieces of 2x4 were add for a bit more height. After much thought I decided to 'fuse' the lower leg (where the operator's foot rests) to the powerloader foot to make something more stable for the wearer.
A 1x6 piece was attached on top of the foot and the lower foot is shaped with 1/2" foam insulation and 1/8" Lauan . The lauan paneling is light, and pretty cheap, and it adds a lot of rigidity to the foam. All the foam was cut with a hot wire tool I got from a craft store and then sanded smooth.
114 comments
1-40 of 114next »
Jan 23, 2010. 9:09 AMcucumber288 says:
who thinks the world is gonna end in 2012?
Jan 5, 2012. 6:25 PMtinker234 says:
here is a tip instead of waiting for it end which is unknown so just live
Oct 31, 2010. 6:32 AMking kolton9 says:
sigh the myan calanders where melted down by the brittish for gold ok. now the one that dates the farthest in the future from that time that we have that was not melted down was the 2012 calander. So the world won't end
Oct 29, 2010. 5:47 PMrattyrain says:
If it does, flaming_pele is prepared!
Sep 16, 2011. 10:17 AMedavis11 says:
wow this is so amazing O.O I was just curious if there are any patterns i could look up for the peices or is it a lot of scaling up and such i'm definetley gonna try this even just to go to a convention ^^ Very inspiring thanks for the instructables
Sep 2, 2011. 9:51 AMpretel says:
Ficou muito boa. Parabéns!
Apr 8, 2011. 11:22 PMdrpots says:
how much did it cost?
Nov 23, 2010. 10:12 PMcalicos says:
oh, this is insanely good! Very impressed with your showing on Attack of the Show and since they say that imitation is the highest form of flattery, I'd say you were very flattered by the Halloween episode last week on Community! If you didn't see it, check out hulu! This is, again, is just incredible -- great job!
Nov 13, 2010. 10:02 AMtonysoprano6379 says:
Outstanding!!!!!!!!!!!
I really liked this instructable! Congrats on getting the mention on G4!!
Nov 1, 2010. 3:26 PMrapidprototyping says:
girlfriend with a backhoe (Wanted) please send photo of backhoe
Sep 30, 2010. 9:32 AMmettaurlover says:
I'm probably going to build one of these for my costue next year.
Sep 11, 2010. 8:32 PMWhiteTigerTails says:
Knowing me, I would probably start adding motors and junk, eventually making it an Audrino/MAKE powered telemetry powered anamatronic suit, that had working parts. Scary as it is, I'd probably start actually making some metal parts and using hydraulics. I'm that batsh!t insane!
Sep 16, 2010. 11:13 AMrichdoe says:
please do that. really that would be extremely cool!
Jul 31, 2010. 6:58 AMKiteman says:
Just an idle thought - what happened to the costume?
Is it on proud display somewhere? Or mouldering in storage?
Aug 16, 2010. 12:27 PMKiteman says:
Excellent!
Jul 11, 2010. 1:16 PMZaros says:
Very nice costume! I'm going to try my hand at it, but I would like to know if you had any blueprints or stencils, etc. for the shapes needed, as I can't figure out what I need to cut out.
Jul 13, 2010. 4:58 PMZaros says:
Thanks for that. I'll get back to this project sometime, but since I'm only a beginner I'm deciding on building something less difficult than this.
Jan 23, 2010. 9:13 AMcucumber288 says:
does it ever mention how much money it would take to build it
Oct 26, 2009. 2:31 PMsherwoodm47 says:
that is totally wicked.... like holly crow thats kool. do you have any other costumes like that or ideas? i would like to see you pst your other owns and or ideas.
peace out
Nov 7, 2008. 2:32 PMBoomshadow says:
Outstanding costume! Loved the instruction set, too. Very clear. How much did everything cost, all told? Would it be cruel to request itemized costs?
Oct 18, 2009. 7:27 PMTori^sStory says:
I would also like to know the total cost...
Sep 2, 2009. 12:51 PMNeofelis44 says:
The Shoulder Joint 2 questions: I understand the two elbows that are not glued, so they can spin, but the joint that allows rotation, you describe it as "a blot through a slot to allow rotation". I went to the hardware store and looked at the various PVC pipe connectors and couldn't figure out what you mean. Could you elaborate a little more for me? Also, how exactly do the elbow ends of the joint get connected to the arm? (Are you gluing the PVC to the foam, or is there a screw that can screw into the 1/8" plywood from the opposite side, or something?)
Sep 2, 2009. 4:03 PMNeofelis44 says:
I really appreciate that. Thanks for the quick response. Maybe I can get the word picture started. I see the Half Tee and the Full Tee. It looks like the Full Tee is a smaller size than the Half Tee. So I can use real numbers, let me assume that the Half Tee is 1" and the Full Tee is 3/4". It looks like a piece of straight pipe (1") is coming out of the Half Tee, and a piece of straight pipe (3/4") is comming out of the Full Tee, possibly inserted into the 1" straight pipe. What keeps that from just sliding back out?
Sep 3, 2009. 8:59 AMNeofelis44 says:
This is awesome. I was trying to come up with an alternate that would allow full rotation, and I think I still might give it a try. Here's my idea:
Sep 3, 2009. 10:50 AMNeofelis44 says:
PVC Rocks! I think I'll give this bolt and slot another chance. I definitely need disasembly capability.
Sep 2, 2009. 12:54 PMNeofelis44 says:
One more forward thinking question: Styrofoam and Paint What do you have to spray styrofoam with so you can spray paint it without dissolving it?
Aug 21, 2009. 2:38 PMNeofelis44 says:
How exactly do the upper legs connect to the main body at the torso area? (Awesome costume by the way. I'm inspired.)
Aug 24, 2009. 8:20 AMNeofelis44 says:
That's exactly what I was thinking. I couldn't think of a way to make a flexible enough joint to allow range of motion in walking. (My concern was in being able to walk through a doorway -- possibly sideways, due to the width of the costume.) Excellent concept. Mine is starting to come along. I'm still in planning stages, though. I haven't actually cut anything yet.
Aug 12, 2009. 8:21 PMcodongolev says:
princess leia is looking at her with intense hate... " that costume contest was mine.... I will destroy you...."
Jul 13, 2009. 3:37 AMNastySpill says:
Do you have copies of those stencils available per chance? Very well done!
Jul 5, 2009. 12:26 PMlaxap says:
Truly awesome work !!!
Shall we dance ?
1-40 of 114next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
52
Author:flaming_pele!
Web developer by day. Gamer by night. DIYer, all the time! My projects tend to combine technology and craftsmanship to produce something that's fun to use and cool to look at.
